when i render the animation it is way brighter than the regular render. How do i fix that?
I pressed the "fill in current setup" but it doesn't do anything.
Moderator: BK
Can you post a screenshot of the Preferences and Animation panels pls? And if you export to Alembic from the System tab and open the resulting .ORBX file from Octane Standalone, does it also render over-exposed? Also, which version of the plugin are you running pls?no
face_off wrote:Do you get the same level of over exposure when you do a normal render with the Final button clicked?
Can you pls send me a simple .duf scene (with say just a cube) which exhibits this problem pls, and I will take a further look.I'm having the same problem and none of the mentioned ways is working... It's very annoying and it happens from a long time ago I always tried to just change exposure and light to match normal render, but it's very hard and time consuming...
Is there any solution?
Users browsing this forum: No registered users and 21 guests
