PXL+DIRT grunge/dirt helper [2019/10/10 update]
Forums: PXL+DIRT grunge/dirt helper [2019/10/10 update]
Moderator: aoktar
Re: PXL+DIRT grunge/dirt helper (2017/05/27 update)
Postby underworldtr » Sun May 28, 2017 9:45 am
underworldtr Sun May 28, 2017 9:45 am
Huge time saver! Thanks for your great work pxlntwrk...
C4D r18.048 / Octane Render Plug-in 3.06 / Turbulence FD (Build 1425) / X Particles 3.5
Titan X & GTX 1080
Win 7 Ultimate
underworldtr
Postby VVG » Mon May 29, 2017 9:32 am
VVG Mon May 29, 2017 9:32 am
pxlntwrk wrote:hi,
new version
update on top of the first post..
viewtopic.php?f=30&t=59827&hilit=pxl#p306211
Cheers
cool!!
Thanks you pxlntwrk
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
VVG
Postby drmaddogs2 » Tue May 30, 2017 10:41 am
drmaddogs2 Tue May 30, 2017 10:41 am
Absolutely love the last edition, very respectable time in the Plug for adding Mat layers! Twice as fast as any I've used. Here's to hoping some improvements come as to 'Ranges' and more Materials.. I'll happily submit a fee for a completed and commercial charge for the work you have accomplished! Even at this stage of development, lol!
drmaddogs2
Postby Elvissuperstar007 » Tue May 30, 2017 11:46 am
Elvissuperstar007 Tue May 30, 2017 11:46 am
And you can create such a plugin to 3ds max , Price put, you have a lot of people will buy
win 7 /64x C2Quad 6600 2.4/ Nvidia 9800 GX2 1gb 512 bit + Asus 480 GTX/ DDR2 8Gb / NVIDIA 460 GTX 2GB/2x NVIDIA 580 GTX 3GB
Elvissuperstar007
Postby pxlntwrk » Tue May 30, 2017 9:45 pm
pxlntwrk Tue May 30, 2017 9:45 pm
many thanks for kind words ;)
@drmaddogs2 : At the very base it is only a personal tool. So I do not think of doing maintenance or improvements. If there are changes, the mind will be more towards simplification, which will be more suitable for my everyday use.
@Elvissuperstar007: Oh, it's been a while since I opened this old bear,
However the nodes are there, and someone may be able to try to drive them with a 3ds max script system similar to Xpresso in Cinema 4d. If I am capable, I would be happy to help!
Ciao
pxlntwrk.net
pxlntwrk
Postby drmaddogs2 » Wed May 31, 2017 9:21 am
drmaddogs2 Wed May 31, 2017 9:21 am
pxlntwrk Thanks again, I find your, ' personal tool' is comparable like where Brograph Luminous helps eliminate building from scratch, and substantially has benefits Octane doesn't address. Not 'plugging' "Luminous", just saying you produced a fine effort(might want to give a call to Brograph.. they like these ideas!).
Any other 'personal tools' you might want to share??????? :idea:
drmaddogs2
Postby pxlntwrk » Mon Jun 12, 2017 1:46 pm
pxlntwrk Mon Jun 12, 2017 1:46 pm
@drmaddogs2: thanks, I will think about it ;)
Here is a small sequence, showing another example of use
more info on this xpresso setup : here and there
ciao !
pxlntwrk.net
pxlntwrk
Re: PXL+DIRT grunge/dirt helper (2017/06/13 update)
Postby pxlntwrk » Tue Jun 13, 2017 7:24 pm
pxlntwrk Tue Jun 13, 2017 7:24 pm
pxlntwrk.net
pxlntwrk
Postby raul_pier » Wed Aug 09, 2017 4:45 am
raul_pier Wed Aug 09, 2017 4:45 am
Great I just order it.
update... 8/8
Seems like if Sticker is not working under Ver R16.050, I am not getting the option
Sticker.1
....bitmap RGBa
Like in the tutorial, where I can pick a sticker.
update.. 8/10
It worked perfectly under ver 17,
Amazing tool, easy to use, thumbs up. A+++++++++++++++++++++++++++++
Best regards.
RP
i7 6 Core Processor | ASUS ROG GeForce GTX 1080 Ti 11gb x 2
raul_pier
Postby Adept » Thu Aug 24, 2017 6:17 pm
Adept Thu Aug 24, 2017 6:17 pm
Anyone know if there is a way to use this with multiple materials on one object? I have a single mesh that has 6 different materials applied to it, but in the pxl settings you can only select one "clean material." Any ways to do this? The materials are uv mapped onto the object as well.
EDIT:
I realized I could add the pxl mix mat onto a selection tag for the part I wanted it on.
Adept
PreviousNext
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 38 guests
Fri Apr 26, 2024 12:10 pm [ UTC ]
