Material with the same name
Forums: Material with the same name
Postby fabrizio_s » Thu May 18, 2017 4:32 pm
fabrizio_s Thu May 18, 2017 4:32 pm
when I import an object in a scene with the same material (the same name), rhino (or octane) doesn't ask me if i want to overwrite or duplicate materials with the same name. So I have two identical material...If there a way to avoid it?
thanx
fabrizio_s
Re: Material with the same name
Postby v-cube » Thu May 18, 2017 6:48 pm
v-cube Thu May 18, 2017 6:48 pm
Yes, I have this problem to... the best thing would indeed be a popup which would prompt you with 3 options to chose from:
1. overwrite the existing material with the new one
2. keep the existing material
3. rename the new material
Vary for rhino had such an option ... back in the days
That would be a nice addition...
Best
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
v-cube
Postby fabrizio_s » Thu May 18, 2017 7:51 pm
fabrizio_s Thu May 18, 2017 7:51 pm
Hi Andreas,
yes a popup with these 3 options would be great.
bye
fabrizio
fabrizio_s
Postby face_off » Fri May 19, 2017 8:30 am
face_off Fri May 19, 2017 8:30 am
I have previously raised this issue with the McNeel devs, and did not get a complete answer that was enough to resolve this issue. I suspect this is potentially not possible to implement in Rhino5 with the RhinoCommon API, but may be doable with Rhino 6.
Postby fabrizio_s » Fri May 19, 2017 10:51 am
fabrizio_s Fri May 19, 2017 10:51 am
ok,
thanks a lot
fabrizio_s
Return to Rhinoceros 3D
Fri Apr 26, 2024 2:18 am [ UTC ]
