Rendering in MPlay?
Forums: Rendering in MPlay?
Houdini Integrated Plugin
Rendering in MPlay?
Postby RyanJP » Tue Apr 11, 2017 5:38 pm
RyanJP Tue Apr 11, 2017 5:38 pm
Hi, how do I output a preview render of a sequence to MPlay? When I use Render->MPlay->OctaneROP i see the frames rendering one by one, but in the MPlay window there's no sequence- it only shows one frame and just continually overwrites it as it renders.
Also in a seperate case I have a FEM simulation and the geometry updates in the IPR, but not in MPlay.
What gives?
RyanJP
Re: Rendering in MPlay?
Postby juanjgon » Tue Apr 11, 2017 11:23 pm
juanjgon Tue Apr 11, 2017 11:23 pm
In the Octane ROP node, Output tab, you have the "Override MPlay frame" option. You must disable this option if you want to store the full sequence in MPlay.
If you have problems with the simulations update while rendering a sequence, probably the problem is that you are rendering the animation in "Update" mode. In the Octane ROP node, Main tab, you can select the "Full scene reload" rendering mode. The animations with objects that don't have a constant topology can't be rendered in update mode.
juanjgon
Return to Houdini
Users browsing this forum: No registered users and 21 guests
Sat Apr 27, 2024 8:30 pm [ UTC ]
