Assigning a material to some geometry objects fails (purple)
Forums: Assigning a material to some geometry objects fails (purple)
Houdini Integrated Plugin
Postby mz2 » Tue Mar 07, 2017 7:48 pm
mz2 Tue Mar 07, 2017 7:48 pm
I'm hitting a weird issue with some geometry objects I've created by .obj files imported from AgiSoft PhotoScan: they remain purple when rendered in OctaneRender (i.e. assigning the material appears to be failing?). The same geometry (although it is not clean by any means, it is a really bad quality scan in fact with holes) does not appear to have any issue when rendering with Mantra.
You'll find an example .hiplc over here (the .obj file and the texture file are found in the same folder, as well as a Collada version of the same geometry that is not referenced in the Houdini file):
https://www.dropbox.com/sh/l1r67lyx8i2i ... 8m_fa?dl=0
mz2
Re: Assigning a material to some geometry objects fails (purple)
Postby juanjgon » Tue Mar 07, 2017 9:05 pm
juanjgon Tue Mar 07, 2017 9:05 pm
To assign materials to objects from .obj files you need to use the Material SOP node. The .obj files are imported using geometry groups, that currently must be configured using the Material SOP in the Octane plugin.
juanjgon
Postby mz2 » Tue Mar 07, 2017 10:30 pm
mz2 Tue Mar 07, 2017 10:30 pm
Thanks for yet another super fast response. Is this documented someplace I've missed btw? Just wondering in case I should read some part of the manual for a few more of such noob questions.
mz2
Postby juanjgon » Wed Mar 08, 2017 11:34 pm
juanjgon Wed Mar 08, 2017 11:34 pm
Nope, I think that this workflow is not documented. Anyway, there are a lot of things to update in the docs related to the new 3.0 features, that I hope to add as soon as possible.
juanjgon
Return to Houdini
Users browsing this forum: No registered users and 20 guests
Fri Apr 26, 2024 7:02 am [ UTC ]
