Environment Texture with Ambient Occlusion
Forums: Environment Texture with Ambient Occlusion
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby Philipp1980 » Thu Feb 16, 2017 4:39 pm
Philipp1980 Thu Feb 16, 2017 4:39 pm
Hey,
I've got a question concerning Environment Texture with Ambient Occlusion:
I am trying to render an image with sunlight, environment texture and Ambient Occlusion, I am getting black ceilings in interior rooms (picture 1).
When removing the environment texture in AO or switching to Diffuse/PMC/PT, the ceiling is lit correctly with (picture 2: AO).
How can I solve this? Is it a bug or am I missing sth?
Thx in advance for your help :)
Philipp1980
Re: Environment Texture with Ambient Occlusion
Postby glimpse » Thu Feb 16, 2017 6:02 pm
glimpse Thu Feb 16, 2017 6:02 pm
I don't think it's a bug, but rather a feature..when You're using something like HDRi image of SKY, You have bottom half of that sphere black. Try this with full 360 map & I think the result will be different ;)
glimpse
Postby Philipp1980 » Fri Feb 17, 2017 9:43 am
Philipp1980 Fri Feb 17, 2017 9:43 am
Hey glimpse,
thx for your answer.
You are right, it's related to the black lower half of the sphere. But when using the exact same settings with any other render kernel (Diffuse, PMC, PT), the render result is correct, there are no black faces.
So I'm still not sure if it's supposed to be like this. And I don't want lightning from "the bottom" ;) .
Or is AO supposed to work like this, using the light sources projecting light directly to the opposed faces of the model? Do you know what I mean? ;)
Philipp1980
Postby Goldisart » Fri Feb 17, 2017 10:23 am
Goldisart Fri Feb 17, 2017 10:23 am
try to take any spherical panorama and turn it down to pieces === then simulated stars on the ceiling and land on the floor
only take a similar environment .. if the interior is the interior etc
Goldisart
Postby Philipp1980 » Sun Feb 19, 2017 6:37 pm
Philipp1980 Sun Feb 19, 2017 6:37 pm
Hi Goldisart,
thank you for your answer. I think I understood now how AO is working. The name should have given me a hint :P
Cheers ;)
Philipp1980
Return to Autodesk 3Ds Max
Users browsing this forum: Bing [Bot] and 23 guests
Sun Apr 28, 2024 2:35 pm [ UTC ]
