OctaneRender™ Standalone 3.04.3
Forums: OctaneRender™ Standalone 3.04.3
Re: OctaneRender™ Standalone 3.04.3 [current 3.xx]
Postby manalokos » Wed Nov 02, 2016 7:59 pm
manalokos Wed Nov 02, 2016 7:59 pm
Batch rendering is not working, I press Start, and the progress bar moves fast, says "Finished", nothing done.
manalokos
Please update the benchmark software to Octane 3!
Postby Uhlhorn » Fri Nov 04, 2016 5:10 pm
Uhlhorn Fri Nov 04, 2016 5:10 pm
Please update the benchmark software to Octane 3 and update the result page for Octane 3 benchmarks!
Uhlhorn
Postby andw » Fri Nov 04, 2016 5:59 pm
andw Fri Nov 04, 2016 5:59 pm
abstrax wrote:Fixed broken smooth flag in mix materials, i.e. if all children of a mix material have the smooth option disabled, the mix material will be rendered non-smooth, too (see viewtopic.php?p=293395#p293395).
Nice, thanks! :)
Unfortunately, the annoying bug with 'Mesh' node caching is still here: Octane Render doesn't reload .obj and .mtl files (i.e. not updating materials list) when opening another .ocs scene file with file same file path (as in previously opened scene) to .obj mesh.
AMD R7-2700/64Gb/RTX2080Ti 11Gb + RTX2080 8Gb/Win10 Pro x64/nV driver 451.67/Poser10, DS4.12, Blender2.79, Octane 4.05 Standalone
> Using RAM Disk with Octane <
andw
Postby Elvissuperstar007 » Mon Nov 07, 2016 4:35 pm
Elvissuperstar007 Mon Nov 07, 2016 4:35 pm
OSL Octane he is able to make a plug-in support RichDirt?
viewtopic.php?f=27&t=22197
viewtopic.php?f=82&t=41456
win 7 /64x C2Quad 6600 2.4/ Nvidia 9800 GX2 1gb 512 bit + Asus 480 GTX/ DDR2 8Gb / NVIDIA 460 GTX 2GB/2x NVIDIA 580 GTX 3GB
Elvissuperstar007
Postby rashadcarter » Tue Nov 08, 2016 6:15 pm
rashadcarter Tue Nov 08, 2016 6:15 pm
Something is broken with the Mesh smoothing Flag and Mix materials. I currently cannot get any Mix Materials to render as smoothed. IF I enable smoothing in both mix nodes I get non-smoothed rendering. If I disable both of them I still get non-smoothed rendering. If I enable only 1 of them I still yet get non-smoothed rendering. I see there was a change made in that regard due to a bug that was reported but it has made the issue worse, not better from what I can tell. This is a material that is a Mix from the start. Help is appreciated.
Edit:
It should be noted that this is a problem with all of the 3.04 builds posted so far. I have had to revert to 3.03. These are materials previously built and loaded into the new 3.04 versions. These mix material shaders worked fine in all previous releases before 3.04. Do I have to rebuild the shaders from scratch in the new 3.04 versions for the smoothing bug fix to take effect?
rashadcarter
Postby abstrax » Tue Nov 08, 2016 7:45 pm
abstrax Tue Nov 08, 2016 7:45 pm
rashadcarter wrote:Something is broken with the Mesh smoothing Flag and Mix materials. I currently cannot get any Mix Materials to render as smoothed. IF I enable smoothing in both mix nodes I get non-smoothed rendering. If I disable both of them I still get non-smoothed rendering. If I enable only 1 of them I still yet get non-smoothed rendering. I see there was a change made in that regard due to a bug that was reported but it has made the issue worse, not better from what I can tell. This is a material that is a Mix from the start. Help is appreciated.
Edit:
That should work correctly. Could you post an example please? Thanks.
abstrax
Postby enricocerica » Tue Nov 08, 2016 8:17 pm
enricocerica Tue Nov 08, 2016 8:17 pm
Previously to refresh the project I was working on in the standalone version, I just reloaded it, it was faster than reloading each instance scatter for instance when a project was completely re-exported from the modeling application. This behavior doesn't seem to work anymore, now I have first to select the "new" option in the menu to completely empty the work space and than load my project.
Am I right ? If so, is it intentional or this is a bug ?
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
enricocerica
Postby TRRazor » Tue Nov 08, 2016 8:24 pm
TRRazor Tue Nov 08, 2016 8:24 pm
@abstrax
Any ETA on when transmission will be back working correctly, after it was broken in 3.04.3 (or the one before) ?
Would be great to know, since we would like to release a product soon, and it builds on transmission nodes.
Thanks for your help and time :)
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
TRRazor
Postby abstrax » Tue Nov 08, 2016 8:36 pm
abstrax Tue Nov 08, 2016 8:36 pm
TRRazor wrote:@abstrax
It's fixed already in the development branch and I'm planning to get an update out this Friday. We are trying to roll some changes/improvements to the render job graph stuff into that release, too. I hope that is ok.
abstrax
enricocerica wrote:Previously to refresh the project I was working on in the standalone version, I just reloaded it, it was faster than reloading each instance scatter for instance when a project was completely re-exported from the modeling application. This behavior doesn't seem to work anymore, now I have first to select the "new" option in the menu to completely empty the work space and than load my project.
I will have a look into it.
abstrax
PreviousNext
Return to Commercial Product News & Releases (Download here)
Sat Apr 27, 2024 11:17 am [ UTC ]
