pick material not working with all materials
Forums: pick material not working with all materials
Postby Jorgensen » Wed Jul 13, 2016 12:07 pm
Jorgensen Wed Jul 13, 2016 12:07 pm
hi
when i try to pick materials via picker in the "octane materials" window, octane don't 'detect' the material and don't offer the conversion option.
not sure why it happens. octane does select other materials, but not some specific :-(
i have tried to
- close and open the octane material windows
- restart sketchup
- rename the material to a simple letter
- add a new material to the geometri.
does anyone know how to fix this?
jorgensen
Jorgensen
Re: pick material not working with all materials
Postby azen » Wed Jul 13, 2016 11:15 pm
azen Wed Jul 13, 2016 11:15 pm
Just to clarify, is the issue occurring with LiveDB materials, or your own personal library of materials? Is there a consistent element/setting in the materials that fail? If this is a LiveDB material issue, does the problem occur when downloading the material from the DB, or when you try to apply it to geometry? Does this issue happen when you select multiple geometry, or does it happen even when you select single geometry?
azen
Postby Jorgensen » Thu Jul 14, 2016 9:04 am
Jorgensen Thu Jul 14, 2016 9:04 am
hi azen
sorry if i was unclear - it has nothing to do with the livedb.
it happens when i want to link an existing sketchup material to octane. i normally just pick the texture using the pipette in the octane material window - and then i can select "convert to", in the octane material windows - but sometimes i don't get this option - i pick a material, but nothing happens in the octane material windows.
i just wanted to test again, but could not use the scene - see this error https://render.otoy.com/forum/viewtopic.php?f=31&t=55254
i will post again if it happens.
jorgensen
Jorgensen
Postby Jorgensen » Tue Sep 06, 2016 2:40 pm
Jorgensen Tue Sep 06, 2016 2:40 pm
hi
i still can't pick some materials - is there a fix for this?
thanks
jorgensen
Jorgensen
Postby Jorgensen » Wed Sep 21, 2016 1:09 pm
Jorgensen Wed Sep 21, 2016 1:09 pm
anyone else having this "##¤#"¤# problem?
jorgensen
Jorgensen
Postby azen » Wed Sep 21, 2016 11:52 pm
azen Wed Sep 21, 2016 11:52 pm
Just to clarify:
You select an option from under the "Materials" tab, apply to a piece of geometry, then right-click and "Octane Material -> Convert from Sketchup Material" - is this correct? Do you happen to recall the materials that you had your issue with?
azen
Postby Jorgensen » Thu Sep 22, 2016 6:33 am
Jorgensen Thu Sep 22, 2016 6:33 am
hi azen
i have send you a dm.
jorgensen
Jorgensen
Return to SketchUp
Users browsing this forum: Google [Bot] and 33 guests
Fri Apr 26, 2024 3:53 pm [ UTC ]
