Octane exporter for C4D version 0.12b (current)
Forums: Octane exporter for C4D version 0.12b (current)
Moderator: aoktar
Re: Octane exporter for C4D version 0.12b (current)
Postby Kassad » Thu Apr 23, 2015 8:21 am
Kassad Thu Apr 23, 2015 8:21 am
Hi again,
Octane Exporter for C4D R12 0.13 running fine now on Mac.
Thank you very much.
B->
Kassad
Postby cheeseburger » Sat Sep 10, 2016 5:46 pm
cheeseburger Sat Sep 10, 2016 5:46 pm
Hi Marcus,
Did you resolve that problem where you can't use a camera focus object during animation ?
I'm desperate to find a solution. I've convinced the team that we should use Octane for an animation we're doing ... but this will kill the whole project.
cheeseburger
Postby cheeseburger » Tue Sep 13, 2016 1:12 pm
cheeseburger Tue Sep 13, 2016 1:12 pm
Hi All, just wanted to ask if anyone has a way of doing this ? (Animating camera focus and rendering out the animation successfully)
cheeseburger
Postby bepeg4d » Tue Sep 13, 2016 2:52 pm
bepeg4d Tue Sep 13, 2016 2:52 pm
Hi cheeseburger,
have you tried to export the camera animation with c4d Alembic exporter separately from the scene and import it into Standalone?
ciao beppe
Postby cheeseburger » Tue Sep 13, 2016 3:44 pm
cheeseburger Tue Sep 13, 2016 3:44 pm
Ciao Beppe !
I 'm gonna try it right now, but I believe it's to do with the viewport not refreshing or something like that ... Anyways, Thanks, I'll try that now ..
Grazie
cheeseburger
Postby cheeseburger » Tue Sep 13, 2016 3:49 pm
cheeseburger Tue Sep 13, 2016 3:49 pm
Hi Beppe,
I'm using Octane version 1.55, does that include Alembic import? I couldn't see it any where.
Have you got this working on a particular set up ? I could upgrade I suppose ...
cheeseburger
Postby cheeseburger » Tue Sep 13, 2016 4:00 pm
cheeseburger Tue Sep 13, 2016 4:00 pm
Okay, got it to import but it looks like a whole other lot of stuff to set up. Do you know wether I can get Cinema just to export with the Octane plugin and get the animation actually working(Camera Focal point) ?
Have you tried it ?
Cheers
cheeseburger
Postby bepeg4d » Wed Sep 14, 2016 3:24 pm
bepeg4d Wed Sep 14, 2016 3:24 pm
Hi cheeseburger,
I have just tried with the exporter and Octane 1.55 and everithing works as expected. In my opinion, you don't need to export the camera in Alembic, please have a look at the scene attached and at this screenshots about the proper settings:
CameraFocus_Exporter.7z
(337.47 KiB) Downloaded 1431 times
Here is the mov created with the exporter and octane v1.55:
ciao beppe
Postby cheeseburger » Wed Sep 14, 2016 5:25 pm
cheeseburger Wed Sep 14, 2016 5:25 pm
Ciao Bepe, Thanks so much for having a look at this and uploading those files. I couldn't see a camera where you had an object that controlled the focus distance ... just a key framed one is that right ?
cheeseburger
Postby bepeg4d » Thu Sep 15, 2016 3:15 pm
bepeg4d Thu Sep 15, 2016 3:15 pm
Hi cheeseburger,
you have to animate with keyframes the Focus Distance in the c4d camera. If you want to use an object to control the focus, you need to switch to the integrated plugin.
ciao beppe
PreviousNext
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 34 guests
Sat Apr 27, 2024 7:14 am [ UTC ]
