Lightwave 3D Plugin v0.1
Forums: Lightwave 3D Plugin v0.1
Re: Lightwave 3D Plugin v0.1
Postby 3dworks » Thu Jul 29, 2010 8:39 am
3dworks Thu Jul 29, 2010 8:39 am
i'm trying with LWHC build 2015 and after having to hit for each exported OBJ, in the end i'm always getting 'failed to copy obj' error, no matter what scene i'm trying. i'm just using LW object exporter because on mac, with default settings of exporter plugin.
cheers
markus
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
3dworks
Postby holocube » Thu Jul 29, 2010 11:39 am
holocube Thu Jul 29, 2010 11:39 am
let's debug over skype markus :)
just as a quick test before I can escape the office.. could you load a single object, select it. Open up lscript command in master plugins, in command enter SaveWavefrontObj
press enter and let me know if it exports fine
GTX260 Seven 64bit
I'm Superfrog
holocube
Postby sjonsjine » Thu Jul 29, 2010 12:46 pm
sjonsjine Thu Jul 29, 2010 12:46 pm
can I use it in LW 9.6?
sjonsjine
Postby holocube » Thu Jul 29, 2010 1:12 pm
holocube Thu Jul 29, 2010 1:12 pm
my obj writer(win) should work fine in 9.0 or later
GTX260 Seven 64bit
I'm Superfrog
holocube
Postby sjonsjine » Thu Jul 29, 2010 2:56 pm
sjonsjine Thu Jul 29, 2010 2:56 pm
holocube wrote:my obj writer(win) should work fine in 9.0 or later
I get the message, unknown command "Generic_OctaneExportOBJ"
Help......
sjonsjine
Postby 3dworks » Thu Jul 29, 2010 3:14 pm
3dworks Thu Jul 29, 2010 3:14 pm
holocube wrote:let's debug over skype markus :)
yes it does!
3dworks
Postby holocube » Thu Jul 29, 2010 4:36 pm
holocube Thu Jul 29, 2010 4:36 pm
Help......
did you add OctaneExporter.p ?
GTX260 Seven 64bit
I'm Superfrog
holocube
Postby holocube » Thu Jul 29, 2010 4:44 pm
holocube Thu Jul 29, 2010 4:44 pm
yes it does!
good, my fault = fix :)
GTX260 Seven 64bit
I'm Superfrog
holocube
Postby sjonsjine » Fri Jul 30, 2010 8:06 am
sjonsjine Fri Jul 30, 2010 8:06 am
Help......
yes, I really don't get it
sjonsjine
Postby sjonsjine » Fri Jul 30, 2010 8:11 am
sjonsjine Fri Jul 30, 2010 8:11 am
On my other machine, 2nd license, I get the error: MeshNode for rendring "bla-bla.obj" not useable.
sjonsjine
PreviousNext
Return to Lightwave 3D
Users browsing this forum: No registered users and 27 guests
Sat Apr 27, 2024 12:53 am [ UTC ]
