Do i need to install CUDA Toolkit to get it to work?
This wasn't the case before so is a surprise if so.
I've got NVidia 368.22 drivers, but Cinema won't let the viewport work.
Moderator: aoktar
momade wrote:Hello aoktar.
Thank you for your V3 plugin.
I am completely new to V3 and volumetrics.
This question might have been asked already, but is it right, that i can only fill primitives with fog? once I make i.e. my shpere editable the fog is gone...
Kepp it up!
Mo
momade wrote:Sorry. Even only shperes work. any reason for that?
aoktar wrote:momade wrote:Sorry. Even only shperes work. any reason for that?
Simple and faster. It's experimental atm. Not easy and fast to convert meshes to voxels. It's quite bit job when you think workload of Octane side.
Also i don't advice to use in any work atm. Because i can change behaviour/workflow and parameters for that.
DinoMuhic wrote:Can't make the TurbulenceFD examples provided here to work.
I cached the sims but octane wont show any volumetrics.
I am using the learning edition of TFD, could this be the reason?
Its on Win 10.
eightvfx wrote:Hello !
> login with 3 beta 2 works fine with stand alone and plugin,
but > for 3 release >> impossible to login with same login information.
thanks.
Users browsing this forum: Bing [Bot] and 9 guests
