Version 3.00 - R1.1 (25.05.2016)
Forums: Version 3.00 - R1.1 (25.05.2016)
Moderator: aoktar
Re: Version 3.00 - Beta2.1 (17.05.2016) - Test version
Postby aoktar » Fri May 20, 2016 1:47 am
aoktar Fri May 20, 2016 1:47 am
jayroth wrote:Where is the TFD Flamethrower example file? It is not included in the TFD Examples download...
Added.
Postby jayroth » Fri May 20, 2016 5:18 pm
jayroth Fri May 20, 2016 5:18 pm
Added.
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
jayroth
Postby jayroth » Fri May 20, 2016 7:52 pm
jayroth Fri May 20, 2016 7:52 pm
Sadly, I am not seeing any of the black smoke as seen in the photograph -- I am seeing flame only. I am using Octane 3 Beta 2.1, with Cinema version 17.046 on the configuration listed in my signature. Any ideas?
jayroth
Postby aoktar » Fri May 20, 2016 8:09 pm
aoktar Fri May 20, 2016 8:09 pm
jayroth wrote:Sadly, I am not seeing any of the black smoke as seen in the photograph -- I am seeing flame only. I am using Octane 3 Beta 2.1, with Cinema version 17.046 on the configuration listed in my signature. Any ideas?
Be sure that you have density channel simulated and absorption/scattering is set properly. it doesn't appear without using object tag with proper settings.
Postby kacperspala » Sat May 21, 2016 2:06 pm
kacperspala Sat May 21, 2016 2:06 pm
There is no "scale" in medium node ? Just density ? Does it work the same way ? Cant reproduce some materials now .
ryzer 2700x
rtx 2080Ti
kacperspala
Postby aoktar » Sat May 21, 2016 2:26 pm
aoktar Sat May 21, 2016 2:26 pm
kacperspala wrote:There is no "scale" in medium node ? Just density ? Does it work the same way ? Cant reproduce some materials now .
scale -> density. It's same and renamed as standalone has been like that since some version.
Which material you can't do? It should work as old named scale parameter.
Postby eyeonestudio » Sat May 21, 2016 4:25 pm
eyeonestudio Sat May 21, 2016 4:25 pm
Octane 3.0 is glad to be released soon.
Most people will use Houdini to create openVDB.
Houdini 1unit is 1Meter.
C4D Default Unit is Centimeter.
VDB loader default scale is Meters. But Not Match Scale Houdini VDB. Hectometers is Matched Scale.
Particle Rendering - Dropdown Menu
I want to be a little change .
1.None
2.Sphere
3.Object Instances
4.Voxel
Thanks..... :D
CINEMA 4D R2023
Win10 / 10GbE / AMD3995X*2ea, AMD3990X*2ea, 10980XE*2ea / 256Gb RAM / RTX3090*14ea
eyeonestudio
Postby Yambo » Sat May 21, 2016 4:43 pm
Yambo Sat May 21, 2016 4:43 pm
eyeonestudio wrote:Octane 3.0 is glad to be released soon.
1.None
2.Sphere
3.Object Instances
4.Voxel
Thanks..... :D
+1 for that
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
Yambo
Postby eyeonestudio » Sat May 21, 2016 8:27 pm
eyeonestudio Sat May 21, 2016 8:27 pm
OpenVDB Velocity Motion Blur Testing
CINEMA 4D R2023
eyeonestudio
Postby aoktar » Sat May 21, 2016 8:39 pm
aoktar Sat May 21, 2016 8:39 pm
eyeonestudio wrote:OpenVDB Velocity Motion Blur Testing
all good?
PreviousNext
Return to Releases
Sun Apr 28, 2024 12:12 am [ UTC ]
