OctaneRender 2 for DAZStudio [STABLE]
Forums: OctaneRender 2 for DAZStudio [STABLE]
Moderator: BK
Re: OctaneRender for DAZ Studio 2.24.2 [TEST]
Postby Sorel » Sun Nov 22, 2015 4:25 pm
Sorel Sun Nov 22, 2015 4:25 pm
Installed just now with no problems. Testing a few scenes, everything seems good so far :)
Sorel
Postby Notiusweb » Sun Nov 22, 2015 7:51 pm
Notiusweb Sun Nov 22, 2015 7:51 pm
Not able to access pc until later, just curious, seeing any material conversion improvements, or not just yet? :D
BTW -
This is AWESOME!!!
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Notiusweb
Postby face_off » Sun Nov 22, 2015 10:45 pm
face_off Sun Nov 22, 2015 10:45 pm
This error seems only to be triggered when installing on a NEW workstation on which before OcDS was NOT installed.
If on your computer
- OcDS was allready installed with an older installer
- a OctaneRender_settings.oczdb file was created
- OcDS was activated
- registry entires were created
you will not be able to reproduce the error.
Nevertheless when you manually take steps to reset the workstation to a clear state before OcDS was installed you may be able to reproduce the error again.
I just post this so face_off has a way to reproduce the error.
I STRONGLY recommend other users NOT to do that because you may end up with a whole set of other activation issues.
If you perform only some of those steps your activation Username and Password will not be saved after you enter it and your plugin stays unactivated.
- run the OcDS uninstaller located in C:\Program Files\DAZ 3D\DAZStudio4
- manually delete the files in C:\Users\USERNAME\AppData\Roaming\OctaneRender
- use CCleaner to clear the registry
- restart the workstation
- run new OcDS installer.
- error message is triggered
I believe all the installer activation issues are fixed in the next release.
Postby face_off » Sun Nov 22, 2015 11:03 pm
face_off Sun Nov 22, 2015 11:03 pm
Not yet. If it's not in the release notes, it's not done.
Postby rajib » Mon Nov 23, 2015 7:57 am
rajib Mon Nov 23, 2015 7:57 am
Thanks Paul =) !
Installation ran without issue. Loaded a scene I was working on with the previous version and was able to render it without any problem. Will do further testing.
Best regards,
Rajib
Windows 10 Pro i9-9980XE 128GB RAM|4 x Titan RTX
Houdini 18.5(2020.2.1.2)|Cinema C4D R26|Daz Studio Pro 4.21.0.5(Octane 2021.1.6.83)
NVIDIA 460.89 Studio Standard
rajib
Postby Hubby72 » Mon Nov 23, 2015 10:07 am
Hubby72 Mon Nov 23, 2015 10:07 am
I really want to say i am happily surprised to at least a new version and ongoing dev communication .
You are really very welcome.
due to limited time i will skip this version but i am really happy reading here about new versions and bugfixing.
Win 10 x64 | Zotac Geforce GTX780 6GB, Gigabyte GeForce GTX 960 | Intel Core i7 3770 | 32GB Corsair DDR3-1600 | PNY 480 GB SSD |
My Blog : http://www.subwaytotatooine.de/
My DA : http://hubby72.deviantart.com/
Hubby72
Postby rajib » Mon Nov 23, 2015 11:13 am
rajib Mon Nov 23, 2015 11:13 am
Hi Paul,
Giving the links to 2 issues I posted in another thread.
Render setting export / import issue.
viewtopic.php?f=44&t=51398&p=255893#p255886
Opacity issue.
viewtopic.php?f=44&t=51398&p=255886#p255893
Best regards,
Rajib
rajib
Postby RGUS » Mon Nov 23, 2015 5:53 pm
RGUS Mon Nov 23, 2015 5:53 pm
WOW... look at all those sliders and tabs... I likes it so far... just have to understand what they all do.
Thanks Paul.
RAM: 64GB
OCTANE PLUGIN VERSION: 2022.1..1.302 Prime
DAZ STUDIO VERSION: 4.21.0.5 Pro Edition (64 bit)
RGUS
Postby Sorel » Mon Nov 23, 2015 11:48 pm
Sorel Mon Nov 23, 2015 11:48 pm
Ok my first issue I have found. I am unable to select a camera for animation rendering.
Sorel
Postby face_off » Tue Nov 24, 2015 2:13 am
face_off Tue Nov 24, 2015 2:13 am
This is happening for me too. Was it a problem on the 2.2 version of the plugin?
PreviousNext
Return to DAZ Studio
Users browsing this forum: No registered users and 19 guests
Fri Apr 26, 2024 4:00 pm [ UTC ]
