Version 2.12.2 - final (updated on 18.11.14)
thanks yann,
what's your preview samples? check my settings.
valters
Please improve GUI/Buttons. With new update I'm feeling like an idio* of clicking on refresh button of Life Preview that work..not work...
sent to life preview...stop..resent not working
close life preview and rest octane windows open from the menu...then works...really annoying!
eightvfx
eightvfx wrote:
Great, youre welcome! eightvfx, could you remembered your values that can produce black textures?
eightvfx
the value where 0 in Preview samples and Preview size and opengl samples and texture power.
it works fine without a bitmap texture in the shader.
but with a bitmap. This scene for example gave me that >
i should be able to see the texture on the object in the viewport right ?
Thank you very much for your attention to this.
Have a good day!
eightvfx wrote:the value where 0 in Preview samples and Preview size and opengl samples and texture power.
Have a good day!
yes it should show up textures on opengl. Also don't check "experimental". I'm not sure what's the problem. I advice to all that should test on different scenes and scenarios first before sending anything as a issue or bug. Not for you, thanks
garytyler
I have been having the same issue as valters, where the Live View doesn't update like it should and the refresh is very inconsistent. It works correctly about a third of the time.
Also, settings do not update to the picture viewer correctly. What I've had to do to fix this is enable 'overwrite kernel settings' and manually put my settings in there. I wouldn't mind this so much if I could access my presets in the 'overwrite' tab. Because I can't, this is very annoying.
Win 8.1 / C4D R16 / Maya '16 / 5x GTX 980 Ti
garytyler wrote:I have been having the same issue as valters, where the Live View doesn't update like it should and the refresh is very inconsistent. It works correctly about a third of the time.
hmm, weird. Are you sure that you are using correct the things? I'm using the plugin for doing jobs and so testing in production environment. Also lot of people is using without this kind of problems. No one says that's "annoying". Can you show something to us except words? Maybe some video capture would be great. Thanks
valters wrote:Please improve GUI/Buttons. With new update I'm feeling like an idio* of clicking on refresh button of Life Preview that work..not work...
ok show me please what are you doing and it does not. I'm very curious to see your usages.
PiotrAdamczyk
I dont know if anyone pointed this out already, but mix materials with opacity maps dont work correctly in info channel passes, I made the leaves with mix material, and ambient occlusion/zdepth pass shows the whole plane without the alpha.
Return to “Releases”
