OctaneRender™ for LightWave™ 1.5 beta - build 1.31.2
Forums: OctaneRender™ for LightWave™ 1.5 beta - build 1.31.2
Re: OctaneRender™ for LightWave™ 1.5 beta - build 1.31.2
Postby polytek » Mon Feb 17, 2014 7:04 pm
polytek Mon Feb 17, 2014 7:04 pm
I try ed both, in pause and just running, sometimes it reacts, sometimes not....
Poly
win 8.2 / 64 / systemmem 27Gb / gtx 750Ti & asus stricks Gtx 780 6Gb
polytek
Postby juanjgon » Mon Feb 17, 2014 8:05 pm
juanjgon Mon Feb 17, 2014 8:05 pm
polytek wrote:I try ed both, in pause and just running, sometimes it reacts, sometimes not....
Poly
Currently if IPR is in pause mode or stopped, export functions don't work. Rendering should be working. Anyway I am going to review the code for the next release to see if I could fix this issue. Here in my tests all works fine, but I need to make more tests.
juanjgon
Postby polytek » Mon Feb 17, 2014 8:39 pm
polytek Mon Feb 17, 2014 8:39 pm
Thank you,
polytek
Postby BorisGoreta » Fri Feb 21, 2014 4:42 am
BorisGoreta Fri Feb 21, 2014 4:42 am
I think that limited region rendering is not taking into account camera shift value. So in scenes with camera shift limited region rendering is not possible.
BorisGoreta
Postby juanjgon » Fri Feb 21, 2014 9:09 am
juanjgon Fri Feb 21, 2014 9:09 am
BorisGoreta wrote:I think that limited region rendering is not taking into account camera shift value. So in scenes with camera shift limited region rendering is not possible.
Yes, plugin camera region uses it's own shift system to work, so the camera shift doesn't work. I hope to see soon a native limited region inside Octane API.
juanjgon
Postby BorisGoreta » Fri Feb 21, 2014 9:52 pm
BorisGoreta Fri Feb 21, 2014 9:52 pm
If I multi select lights and change something while IPR is working IPR restarts rendering for the number of selected lights when it should update all at once
BorisGoreta
Postby BorisGoreta » Sun Feb 23, 2014 5:25 pm
BorisGoreta Sun Feb 23, 2014 5:25 pm
Is it ok if I create a new node in the node editor like Texture Mixer for IPR to immediatley refresh ? This node is just sitting there and it is not connected to anything. I don't think IPR should reflresh. I have noticed a lot of IPR refreshes when not neccessary.
BorisGoreta
Postby juanjgon » Mon Feb 24, 2014 10:16 am
juanjgon Mon Feb 24, 2014 10:16 am
BorisGoreta wrote:If I multi select lights and change something while IPR is working IPR restarts rendering for the number of selected lights when it should update all at once
BorisGoreta wrote:Is it ok if I create a new node in the node editor like Texture Mixer for IPR to immediatley refresh ? This node is just sitting there and it is not connected to anything. I don't think IPR should reflresh. I have noticed a lot of IPR refreshes when not neccessary.
Both issues comes from the same functions. When something changes in the scene, Layout sends messages to the master plugin to allow update the Octane scene. Problem is that this messages sometimes are useful and others not, and it is not easy to know if we should update the scene or not ... for example add a node to the node editor send a "change surface" message, but nothing has changed from the rendering point of view because node is not linked yet, and this is something really hard to know.
Anyway I am going to try to fix some of this issues if possible.
juanjgon
Postby gigi » Mon Feb 24, 2014 12:44 pm
gigi Mon Feb 24, 2014 12:44 pm
hi, i have a problem, when I launch the Layout this message appears. depends on what?
Pc laptop | Corei7 at 2.8GHz | 16GB | GeForce GTX 980M 8 GB | 240 GB SSD | 500 GB 7200 Rpm| Windows 8.1 pro 64 |
gigi
Postby juanjgon » Mon Feb 24, 2014 1:14 pm
juanjgon Mon Feb 24, 2014 1:14 pm
gigi wrote:hi, i have a problem, when I launch the Layout this message appears. depends on what?
You are mixing the Octane.dll/Octane.dat files with an older or newer version of the Octane .p plugin file. Please, be sure that you have the Octane.dll/Octane.dat files and the plugin file from the same .zip archive.
juanjgon
PreviousNext
Return to Lightwave 3D
Users browsing this forum: No registered users and 17 guests
Fri Apr 26, 2024 10:04 am [ UTC ]
