Texture maps with transparency
Forums: Texture maps with transparency
Postby fibernaut » Thu Jan 16, 2014 2:37 pm
fibernaut Thu Jan 16, 2014 2:37 pm
Hi guys
i want to assign a logo to a model. The logo is a png file with transparency. When i put that into the diffuse channel of my material node the logo area seems to be filled with a black background. In lightwave i often use multiply or add to get a logo or any transparent texture on a model. How can i achieve this in octane? Thanks for any help.
Win 10 64 | 2x RTX 3080Ti 2x Xeon E5 2650v2 Supermicro X9DAi 128 GB
Win 10 64 | 1x RTX 4090 i9 9900K Gigabyte z390 128 GB
Win 10 64 | 2x RTX 3080Ti i7 2600 K 32 GB
fibernaut
Re: Texture maps with transparency
Postby FrankPooleFloating » Thu Jan 16, 2014 3:50 pm
FrankPooleFloating Thu Jan 16, 2014 3:50 pm
Double-click the Texture Image node you have your image in. Then change to Alpha Image in Node Type.
FrankPooleFloating
Postby fibernaut » Thu Jan 16, 2014 4:02 pm
fibernaut Thu Jan 16, 2014 4:02 pm
It is already set to alpha image. Does octane need a specific file type?
Edit: The main material is plastic (diffuse mat. with turbulence). I only want to add a logo on top of it like with lightwave blending modes.
fibernaut
Postby FrankPooleFloating » Thu Jan 16, 2014 4:39 pm
FrankPooleFloating Thu Jan 16, 2014 4:39 pm
32bit PNG should work... do you have Alpha Enabled in the LW Image Editor dialog?
Trying to remember how I overlay something without having LW open... I think I use 2 materials and use Material Mixer.. and a 24bit b/w image (opacity map) for the one I want to overlay - and plug into amount... ya, that's da ticket.
FrankPooleFloating
Postby juanjgon » Thu Jan 16, 2014 11:35 pm
juanjgon Thu Jan 16, 2014 11:35 pm
I think that the way to get this effect is to use the image twice, one for apply the color to the object using the texture node as "color image", and other with the texture node set to "alpha" linked to the opacity input.
juanjgon
Postby fibernaut » Fri Jan 17, 2014 6:47 am
fibernaut Fri Jan 17, 2014 6:47 am
Thank you both. I'll try that later. For now i have to stick to lw renderer to get the project done. :|
fibernaut
Postby fibernaut » Sun Jan 26, 2014 10:55 am
fibernaut Sun Jan 26, 2014 10:55 am
FrankPooleFloating wrote:I think I use 2 materials and use Material Mixer.. and a 24bit b/w image (opacity map) for the one I want to overlay - and plug into amount... ya, that's da ticket.
Thanks FrankPooleFloating. Works fine!
fibernaut
Return to Lightwave 3D
Users browsing this forum: No registered users and 23 guests
Fri Apr 26, 2024 4:13 pm [ UTC ]
