Export Revit scene to stand alone Octane
Forums: Export Revit scene to stand alone Octane
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Re: Export Revit scene to stand alone Octane
Postby scottbroad » Fri Sep 13, 2013 7:26 am
scottbroad Fri Sep 13, 2013 7:26 am
You can try it - http://www.inglegreen.com
Clive Broadhurst
Win 10-64bit, i7-3770K, 16Gb, GTX970
Revit 2015, Blender
scottbroad
Postby Jorgensen » Fri Sep 13, 2013 7:30 am
Jorgensen Fri Sep 13, 2013 7:30 am
Super cool - I will try to play around with it :-)
Any known issues?
Thank a lot!! :-)
I will probably buy it or kiss you.
Jorgensen
Postby scottbroad » Fri Sep 13, 2013 7:40 am
scottbroad Fri Sep 13, 2013 7:40 am
I think it's only going to work with Revit 2014 variants ...
It uses the new exporter in the Revit 2014 API ...
Clive Broadhurst
Revit 2015, Blender
scottbroad
Postby Jorgensen » Fri Sep 13, 2013 9:09 am
Jorgensen Fri Sep 13, 2013 9:09 am
Hi Clive
I just did a quick test.
As you can see, I have some issues trying to export this very simple building.
I use Revit 2014.
I don't expect you to provide support - I'll just let you know.
Jorgensen
Jorgensen
Postby scottbroad » Fri Sep 13, 2013 9:38 am
scottbroad Fri Sep 13, 2013 9:38 am
Are you viewing the OBJ in 3DS MAX (Design)?
The OBJ files are too simple at the moment for 3DS MAX (Design). How does it look in Octane Render?
Clive Broadhurst
Revit 2015, Blender
scottbroad
Postby Jorgensen » Fri Sep 13, 2013 9:42 am
Jorgensen Fri Sep 13, 2013 9:42 am
Agrh sorry Clive, I should have pointed it out.
The render is frome the standalone version of octane. the two others are from inside Revit 2014.
Jorgensen
Jorgensen
Postby scottbroad » Fri Sep 13, 2013 9:53 am
scottbroad Fri Sep 13, 2013 9:53 am
strange ...
Just tried to copy your model and it seems ok ...
Can you email me your Revit file please? Email address is on my website ...
Clive Broadhurst
Revit 2015, Blender
scottbroad
Postby Jorgensen » Fri Sep 13, 2013 10:05 am
Jorgensen Fri Sep 13, 2013 10:05 am
Hi Clive
I have sent you the file.
Jorgensen
Jorgensen
Postby azims » Thu Apr 09, 2020 8:29 pm
azims Thu Apr 09, 2020 8:29 pm
Hi Clive,
I am very grateful for your OBJ exporter. Unfortunately it is nor working for Revit 2020. Is it possible to update the exporter to work with Revit 2020?
Azims
azims
Previous
Return to Autodesk Revit
Tue May 21, 2024 1:12 am [ UTC ]
