OctaneRender™ for LightWave™ v1.10 released
Forums: OctaneRender™ for LightWave™ v1.10 released
Re: NEW : OctaneRender™ for LightWave™ v1.10 released
Postby rojharris » Sun Mar 17, 2013 2:18 pm
rojharris Sun Mar 17, 2013 2:18 pm
Hi There,
I'm new to Octane and still getting my head around a few things but I am liking the results I'm getting so far. One question though, When I set up a scene in LW with no octane lights and no environment set, how come the scene is still lit? I'm seeing an overall diffuse light even though my bg is set to black (although it makes no difference what I set it to in the backdrop panel). I would have expected a black bg until I 'switched on' an environment??
Roger
rojharris
Postby juanjgon » Sun Mar 17, 2013 2:44 pm
juanjgon Sun Mar 17, 2013 2:44 pm
rojharris wrote:Hi There,
Roger
By default if you don't have octane lights, emissive geometry or an evironment node inside the render target node editor, plugin add a white texture environment to allow see something whithout more settings. If you want a scene without any kind of environment lighting you must add to the render target a texture environment with color set to black.
juanjgon
Postby rojharris » Sun Mar 17, 2013 2:47 pm
rojharris Sun Mar 17, 2013 2:47 pm
Ah, great. Thanks Juanjo
rojharris
Postby juanjgon » Sun Mar 17, 2013 2:54 pm
juanjgon Sun Mar 17, 2013 2:54 pm
rojharris wrote:Ah, great. Thanks Juanjo
In fact plugin always add a pure white texture environment if you don't have any environment linked in the render target editor, even if you have lights or emissive geometry in the scene.
juanjgon
Postby aw1 » Sun Mar 17, 2013 4:10 pm
aw1 Sun Mar 17, 2013 4:10 pm
Is there anyway to animate target of focus to make "shifting focus" effect? I want to make a null and use it as the focus object and animate it to make shifting focus effect..
Windows 7 Pro, i7 4770, 16 GB Ram, 1TB SSD, Asus GTX780Ti 3GB
aw1
Postby juanjgon » Sun Mar 17, 2013 4:12 pm
juanjgon Sun Mar 17, 2013 4:12 pm
aw1 wrote:Hi,
You only need to link a LW constant node to animate any render targer parameter unsing the constane "E" envelope.
juanjgon
Postby aw1 » Sun Mar 17, 2013 4:28 pm
aw1 Sun Mar 17, 2013 4:28 pm
juanjgon wrote:
aw1 wrote:Hi,
Working :)
aw1
Postby polytek » Sun Mar 17, 2013 5:02 pm
polytek Sun Mar 17, 2013 5:02 pm
juanjgon, just a question, maybe it's just me having a little problem to adjust from the standalone to the lightwave plug, it feels kinde strange....but my question is..in stand alone some input parameters are don with sliders (from 0 to 1 value, etc...), in the plug these value are replaced with a black to white tone wich represend the value 0 to 1 i guess (for example the specular input for the glossy material), and some inputs like for example "bump power value" has a numeric input if you plug in a texture image....now my problem is wat is the range off these values, is it from 0 to 1 (where 0 is nothing and 1 is max) for bump value, are is there no limit wath so ever...it would be easier for me to now wat range and influence these settings have, you now a min max representation.....anyway very nice plug....but i nead to get my head arround it
Polytek
win 8.2 / 64 / systemmem 27Gb / gtx 750Ti & asus stricks Gtx 780 6Gb
polytek
Postby juanjgon » Sun Mar 17, 2013 5:22 pm
juanjgon Sun Mar 17, 2013 5:22 pm
polytek wrote:juanjgon, just a question, maybe it's just me having a little problem to adjust from the standalone to the lightwave plug, it feels kinde strange....but my question is..in stand alone some input parameters are don with sliders (from 0 to 1 value, etc...), in the plug these value are replaced with a black to white tone wich represend the value 0 to 1 i guess (for example the specular input for the glossy material), and some inputs like for example "bump power value" has a numeric input if you plug in a texture image....now my problem is wat is the range off these values, is it from 0 to 1 (where 0 is nothing and 1 is max) for bump value, are is there no limit wath so ever...it would be easier for me to now wat range and influence these settings have, you now a min max representation.....anyway very nice plug....but i nead to get my head arround it
Polytek
Yes, you are right, at some point I am going to add limits to all plugin parameteres, it is in my roadmap.
juanjgon
Postby polytek » Sun Mar 17, 2013 5:50 pm
polytek Sun Mar 17, 2013 5:50 pm
That's fine, you've don a marbelous job so far....
Greetsss
polytek
PreviousNext
Users browsing this forum: No registered users and 45 guests
Fri Apr 26, 2024 9:56 pm [ UTC ]
