Concrete near the lake
Forums: Concrete near the lake
Postby enricocerica » Sun Mar 10, 2013 3:29 pm
enricocerica Sun Mar 10, 2013 3:29 pm
Not much time to work on my last project so I decided to revisit an old project to heat up my video cards ;)
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
enricocerica
Re: Concrete near the lake
Postby PAQUITO » Sun Mar 10, 2013 4:57 pm
PAQUITO Sun Mar 10, 2013 4:57 pm
Lots of potential on that scene, but I think is not well solved. It looks like an abandoned place with all that rust textures and the high contrast. I assume it is retouched. Can we see the raw render?
AMD FX8350 8 cores. 16GBs RAM
GTX690
Win8 64.
PAQUITO
Postby paoloverona » Sun Mar 10, 2013 6:42 pm
paoloverona Sun Mar 10, 2013 6:42 pm
I like the mood that you give to your renders Enrico, this one sounds too much "melancholy" for my tastes but I like that your renders gives some emotional impact.
I'm agree with Paquito.....would be amazing compare the raw with the retouched
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
paoloverona
Postby Refracty » Sun Mar 10, 2013 7:43 pm
Refracty Sun Mar 10, 2013 7:43 pm
I don't think there is much of retouch work done in this image.
I like the mood and environment.
I think it would be nice to step a few meters back and see a bit of the lake / water.
Refracty
Postby enricocerica » Sun Mar 10, 2013 8:12 pm
enricocerica Sun Mar 10, 2013 8:12 pm
Hi and thanks for viewing,
I added the original image to show the result before postprocessing.
I wanted some dramatic result which imo works fine with this environment, I already changed a bit the result to get less contrast but will publish later on to let you first comparte the two images.
I also added more images ;)
enricocerica
Postby Refracty » Sun Mar 10, 2013 8:57 pm
Refracty Sun Mar 10, 2013 8:57 pm
well done enrico
Refracty
Postby paoloverona » Sun Mar 10, 2013 9:03 pm
paoloverona Sun Mar 10, 2013 9:03 pm
super the new images
paoloverona
Postby PAQUITO » Mon Mar 11, 2013 12:06 am
PAQUITO Mon Mar 11, 2013 12:06 am
The last three images are stunning. Congratulations.
About the general shot, if you don´t mind, I´ve been playing a bit with post production and got this result. You can achieve greater results using a material_ID pass.
GTX690
Win8 64.
PAQUITO
Postby PAQUITO » Mon Mar 11, 2013 12:26 am
PAQUITO Mon Mar 11, 2013 12:26 am
By the way... How do you combine an hdri environment with a daylight?
GTX690
Win8 64.
PAQUITO
Postby Carl S. » Mon Mar 11, 2013 4:42 am
Carl S. Mon Mar 11, 2013 4:42 am
PAQUITO wrote:The last three images are stunning. Congratulations.
This result looks washed out and low contrast IMO.
Carl S.
Next
Return to M is for Metaverse Gallery
Users browsing this forum: No registered users and 30 guests
Fri Apr 26, 2024 11:15 am [ UTC ]
