Rhino 5 to Octane Texture Mapping Issue
Forums: Rhino 5 to Octane Texture Mapping Issue
Postby vanhage » Tue Jan 22, 2013 2:13 am
vanhage Tue Jan 22, 2013 2:13 am
Hello All,
Just bought my license of Octane yesterday, really excited to see what it can do.
I'm having an issue where my uv mapping from rhino isn't being imported properly into Octane. I did a simple test to see if the OBJ file would work in Maya and it did. What am I doing wrong?
Win 8 64 | 2X Geforce GTX680 | i7-3770K Ivy Bridge 3.5GHz | 32GB
vanhage
Re: Rhino 5 to Octane Texture Mapping Issue
Postby FooZe » Tue Jan 22, 2013 2:30 am
FooZe Tue Jan 22, 2013 2:30 am
Hi Vanhage,
Can you please an attachment of the .obj, .mtl and texture file.
Also a screen shot of your file->preferences->Obj mesh Import settings
Chris.
FooZe
Postby vanhage » Tue Jan 22, 2013 7:57 pm
vanhage Tue Jan 22, 2013 7:57 pm
Solved.
I made a diffuse material with the diffuse color set to a checksmix node and apparently the checksmix node overrides the texture coordinates. When I eliminate the checksmix and use an image of a checker map instead it appears normal.
Thanks for your reply Chris!
vanhage
Postby FooZe » Tue Jan 22, 2013 10:50 pm
FooZe Tue Jan 22, 2013 10:50 pm
Hi vanhage,
Ok, good to see it's sorted.
I did also notice some artifacts in your image that are most likely due to incorrect scale (check around on the forms for how to deal with this or reply here if you can't find anything).
Chris.
FooZe
Users browsing this forum: No registered users and 50 guests
Sat Apr 27, 2024 4:22 pm [ UTC ]
