What are these black areas?
Forums: What are these black areas?
Postby sublime » Tue Apr 13, 2010 1:21 pm
sublime Tue Apr 13, 2010 1:21 pm
Hi guys
I have several questions on this test scene I made. As shown on the attached images, the first box set are rendered nice and grey, but when I applied glossy material these black areas appears on the back sides of the boxes. Any idea what these might be? Also, how do we apply UVW map?
my humble spec: Quad Cores Q6600 @ 2.4 Ghz, 2GB, GeForce GTX 460 (x2), winXP 32 bit, 3DS MAx 2009
sublime
Re: What are these black areas?
Postby radiance » Tue Apr 13, 2010 1:25 pm
radiance Tue Apr 13, 2010 1:25 pm
it's because you have normal smoothing enabled on objects with too high angles between faces.
you should disable the 'smooth' option on the material node.
Radiance
radiance
Postby sublime » Tue Apr 13, 2010 1:38 pm
sublime Tue Apr 13, 2010 1:38 pm
ok radiance, i'll give it a go,..do you have any msn messenger by any chance..? :D :D :)
sublime
Postby radiance » Tue Apr 13, 2010 1:45 pm
radiance Tue Apr 13, 2010 1:45 pm
sublime wrote:ok radiance, i'll give it a go,..do you have any msn messenger by any chance..? :D :D :)
i have already enough private communication, i'd like to leave support on the forums so other can help too. :)
it's not easy having 80 mails in your inbox every morning.
Radiance
radiance
Postby sublime » Tue Apr 13, 2010 1:48 pm
sublime Tue Apr 13, 2010 1:48 pm
hahaha looks like everyone want a piece of you, fair enough, i let you off, what about my second question about UVW, no matter how i move the slider on the scale tab,..the texture remain the same?
sublime
Postby radiance » Tue Apr 13, 2010 1:51 pm
radiance Tue Apr 13, 2010 1:51 pm
sublime wrote:hahaha looks like everyone want a piece of you, fair enough, i let you off, what about my second question about UVW, no matter how i move the slider on the scale tab,..the texture remain the same?
you apply uv maps in your 3d host app prior to exporting.
Radiance
radiance
Postby sublime » Tue Apr 13, 2010 2:16 pm
sublime Tue Apr 13, 2010 2:16 pm
ahh okay, thanks matey
sublime
Return to Demo Version Questions & Discussion
Users browsing this forum: No registered users and 18 guests
Fri Apr 26, 2024 8:28 am [ UTC ]
