OctaneRender® for 3ds Max® Demo available!
Forums: OctaneRender® for 3ds Max® Demo available!
Re: OctaneRender® for 3ds max® Demo available!
Postby Karba » Fri Oct 19, 2012 4:58 am
Karba Fri Oct 19, 2012 4:58 am
zhangyufeng wrote:hi all:I have a question,gtx680 and gtx580 which one is faster in octanerender?
thanks.
They are similar at the moment.
Karba
Postby zhangyufeng » Fri Oct 19, 2012 9:41 am
zhangyufeng Fri Oct 19, 2012 9:41 am
thanks for reply.
zhangyufeng
Postby cancel » Sat Oct 20, 2012 5:25 pm
cancel Sat Oct 20, 2012 5:25 pm
The latest Octane for Max plug-in supports real-time movable geometry, enabling real-time rendered animation previews.
but i can't find it. How you do it?
And is there any ways to add motion blur?
in this video i can defenetly see motion blur, but can't understand wheys to achive it in octane
http://vimeo.com/49507719
cancel
Postby evo » Sat Oct 20, 2012 9:30 pm
evo Sat Oct 20, 2012 9:30 pm
hi, I've just copy the file in the 3ds max 2013x64 directory just as described in the txt file but i've got some error and octane don't start.
(translating by italian version of windows) impossible to find imput cutexrefsetaddress2d_v3 of the procedure in the dynamic connection nvcuda.dll.
after that came this by 3dsmax
DLL <C:\Program Files\Autodesk\3ds Max2013\octane3dsMax.drl>failed to initialize.
Error code 127- unable to find specificated procedure.
Intel Core i7 920 @ 2.67GHz, 6.00 GB, 896 MBGeForce GTX 260 (x2), Windows
RIBS_stairs
http://www.refractivesoftware.com/forum/viewtopic.php?f=5&t=17973
evo
Postby Karba » Sat Oct 20, 2012 11:46 pm
Karba Sat Oct 20, 2012 11:46 pm
cancel wrote:The latest Octane for Max plug-in supports real-time movable geometry, enabling real-time rendered animation previews.
You just have to set Octane properties "movable proxy" to object you want to have to move.
Right click on object/octane properties/set movable proxy.
Regarding motion blur - it is not supported properly yet.
If you want to have simple motion blur, you just have to use standart 3ds max camera with motion blur enabled. It divides one frame into several subframes, render this several subframe and combine several images into one. In this case you have to set less samples per pixel.
Karba
Postby Karba » Sat Oct 20, 2012 11:52 pm
Karba Sat Oct 20, 2012 11:52 pm
evo wrote:hi, I've just copy the file in the 3ds max 2013x64 directory just as described in the txt file but i've got some error and octane don't start.
Are you sure I have copied all files properly?
Octane3dsmax.dlr should be in plugins directory, not in 3ds max root folder.
Karba
Postby evo » Sat Oct 20, 2012 11:58 pm
evo Sat Oct 20, 2012 11:58 pm
Yes all in max root exept for .dlr in plugin folder
RIBS_stairs
evo
Postby Karba » Sun Oct 21, 2012 2:08 am
Karba Sun Oct 21, 2012 2:08 am
evo wrote:Yes all in max root exept for .dlr in plugin folder
What video driver do you use?
Karba
Postby evo » Sun Oct 21, 2012 10:53 am
evo Sun Oct 21, 2012 10:53 am
My system information on nvidia pannel says 280.26. Am i have to update it?
RIBS_stairs
evo
Postby Karba » Sun Oct 21, 2012 7:08 pm
Karba Sun Oct 21, 2012 7:08 pm
evo wrote:My system information on nvidia pannel says 280.26. Am i have to update it?
Definitely
Karba
PreviousNext
Users browsing this forum: No registered users and 90 guests
Sun Apr 28, 2024 5:15 pm [ UTC ]
