What is the reason?
Forums: What is the reason?
What is the reason?
Postby 1332550637 » Tue Feb 21, 2023 12:14 pm
1332550637 Tue Feb 21, 2023 12:14 pm
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFF1577B770)
Tried to access null node pin
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFF1577B770)
Export materials time= 1006.291 ms
Collect objects time= 2.802 ms
Mesh creation time = 24.047 ms.
Failed to build OCIO output transform: No OCIO config loaded
Api update time: 5.255 ms.
MB:0/0 ST/MOV:0/9 Nodes:84 Tris:196k DispTris:0 Hairs:0 Meshes:12
Textures Grey8/16:3/0 Rgb32/64:0/0
This prompt will pop up as soon as you open the octane renderer :( :(
1332550637
Re: What is the reason?
Postby frankmci » Tue Feb 21, 2023 8:32 pm
frankmci Tue Feb 21, 2023 8:32 pm
Does this happen only with a specific project? If so, it sounds like you've got a broken/corrupt shader. Try deleting 1/2 of your materials before opening the renderer. Does is crash? If so, open a fresh copy and delete the other half. If either of those work, then it's a simple matter of dividing by two, over and over, until you find the culprit. This is quick, even with a crazy number of shaders.
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby bacteriashoal » Mon Jul 24, 2023 9:32 am
bacteriashoal Mon Jul 24, 2023 9:32 am
You could try opening the renderer without half of your materials. Is there a crashmini crossword?
bacteriashoal
Return to OctaneVR Questions & Discussion
Who is online
Users browsing this forum: No registered users and 27 guests
Sun Apr 28, 2024 4:21 pm [ UTC ]
