Background render crash
Forums: Background render crash
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby RobotRumpus » Tue Dec 27, 2016 10:50 pm
RobotRumpus Tue Dec 27, 2016 10:50 pm
It seems a script containing an Octane render node will crash a background render, even if that node is disabled.
As I am pre-rendering Octane nodes and submitting scripts to the background, I would like to be able to simply disable Octane for that purpose.
thanks,
~Jason
Robot Rumpus .com
RobotRumpus
Re: Background render crash
Postby face_off » Wed Dec 28, 2016 5:27 am
face_off Wed Dec 28, 2016 5:27 am
Hi Jason - not sure I understand your terminology correctly. Are you able to give me more details on your workflow so I can resolve this issue pls?
Postby RobotRumpus » Wed Jan 04, 2017 6:04 pm
RobotRumpus Wed Jan 04, 2017 6:04 pm
Just to say that if I submit a nuke script to background render, it will crash if there is an octane render node in that script. I understand why Octane would not render in the background, but if I disable the node and use a cached render in my comp, the presence of the Octane node in my script, even though it is disabled and not being used, will still crash the render.
What I am trying to do in my workflow is build a 2D/3D integrated comp, then pre-render the 3D part and temporarily disable the Octane render node while the cached version is in use in the 2D part of the comp. However, even though it is disabled, if I try to submit the shot to background render, it always crashes. This is a minor inconvenience, but it does cost time.
thank you!
Jason
RobotRumpus
Postby face_off » Thu Jan 05, 2017 3:28 am
face_off Thu Jan 05, 2017 3:28 am
Hi Jason - I am not able to reproduce this problem. On Windows I get no error. On OSX I get Nuke reporting a crash, but it does not actually crash and the dialog can be ignored. If I remove the OctaneRender node from the scene completely I still get the crash msg. So is it possible this is a general Nuke bug rather than specific to the plugin?
Postby face_off » Thu Jan 05, 2017 3:37 am
face_off Thu Jan 05, 2017 3:37 am
You can see even this simple scene is crashing for me on OSX when rendering in the background and has not Octane nodes in it.
Postby RobotRumpus » Mon Jan 09, 2017 5:24 pm
RobotRumpus Mon Jan 09, 2017 5:24 pm
Hmm. Interesting. I'll investigate this some more.
thanks,
Jason
RobotRumpus
Return to Bug Reports
Fri Apr 26, 2024 3:00 pm [ UTC ]
