One thing I forgot to mention, is that originally I looked into using a PCI e riser to lift the 4th GPU up away from the mobo , and asked EVGA if they recommend any, they were vague too. Said they cant vouch for ones they havnt tested and most importantly I would then have an issue connecting the GPU to the IO back plate of the case, so I left that possibility and looked into the other options I mentioned in my previous post. I have also been on another thread here:
viewtopic.php?f=30&t=69304&p=351919#p351919( - the thread is actually about fixing the PLX chip issue - )
Anyway I was asking the guy in that thread that had similar issues and same mobo , he just told me that he used a 3M PCI e riser, ( i have seen that this riser - altho more expensive - had good reviews somewhere else too ) The only issue I need to figure out now is how to attach the GPU to my case back plate, Ive aske dthe guy in that thread how he did it, but also EVGA said you could modify the back plate...not sure how but Ill look into it. Maybe even just using longer screws?
