How does SLI harm?
Forums: How does SLI harm?
How does SLI harm?
Postby voon » Wed Aug 02, 2017 2:15 pm
voon Wed Aug 02, 2017 2:15 pm
If SLI poses aproblem, is this a binary issues, i.e. doesn't work at all vs works? Or is it an obscure slowdoan, rare problem etc?
I ask because I occasionally paly games on the render machine and it's always in SLI mode (since changin the mode is a bit of a nuisance to me). I can use blender & otoy plugin and it works usually, but I wonder.
voon
Re: How does SLI harm?
Postby FrankPooleFloating » Wed Aug 02, 2017 4:59 pm
FrankPooleFloating Wed Aug 02, 2017 4:59 pm
Enable/disable sli in control panel.
FrankPooleFloating
Postby bepeg4d » Thu Aug 03, 2017 6:32 am
bepeg4d Thu Aug 03, 2017 6:32 am
Hi voon,
since SLI handles the memory in a different way, you can have VRAM issues if SLI is enabled.
As Frank said, just enable/disble it in Nvidia control panel.
Postby treddie » Sat Feb 17, 2018 12:16 am
treddie Sat Feb 17, 2018 12:16 am
I seem to recall SLI in the NVIDIA CP a long time ago. But when I go back there now, it is gone.
Win7 | Geforce TitanX w/ 12Gb | Geforce GTX-560 w/ 2Gb | 6-Core 3.5GHz | 32Gb | Cinema4D w RipTide Importer and OctaneExporter Plugs.
treddie
Postby FrankPooleFloating » Sat Feb 17, 2018 1:23 pm
FrankPooleFloating Sat Feb 17, 2018 1:23 pm
3D Settings > Configure SLI, Surround, PhysX > SLI Configuration > Disable SLI ;)
FrankPooleFloating
Postby treddie » Sat Feb 17, 2018 11:18 pm
treddie Sat Feb 17, 2018 11:18 pm
Yah...Not there.
Assuming SLI requires that linking cable thing, I'm wondering if it is because I never install the cable, so that maybe the NVIDIA Control panel does not see SLI as an option.
treddie
Postby FrankPooleFloating » Sun Feb 18, 2018 1:10 pm
FrankPooleFloating Sun Feb 18, 2018 1:10 pm
:? I'm using 378.66, which isn't recent, but not that old... Anyway, option to disable is available in my version, even without SLI bridge attached.
FrankPooleFloating
Postby treddie » Sun Feb 18, 2018 11:28 pm
treddie Sun Feb 18, 2018 11:28 pm
Mine looks current. Weird.
treddie
Postby bepeg4d » Mon Feb 19, 2018 11:05 am
bepeg4d Mon Feb 19, 2018 11:05 am
note that the option to untick could be called Multi GPU, instead of SLI.
ciao Beppe
Postby treddie » Mon Feb 19, 2018 11:31 pm
treddie Mon Feb 19, 2018 11:31 pm
The only thing I have is a parameter called "CUDA - GPUs", with a drop-down menu allowing me to select however many of the GPUs I want to use for a particular app.
treddie
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 33 guests
Fri Apr 26, 2024 6:35 am [ UTC ]
