Need Help - Octane Freezes using Google Sketchup 2015
Forums: Need Help - Octane Freezes using Google Sketchup 2015
Postby lcp360 » Sat Feb 18, 2017 3:02 am
lcp360 Sat Feb 18, 2017 3:02 am
I have been scratching my head over this for the last week. I upgraded the GPU's in my device in hopes to make it my "render" machine. I am building my models on one computer, exporting them and importing into my "render" machine. When i load the model and run Octane, it freezes on me each time. When I try and run Octane using a small, simple model it works, but it freezes on large models.
Build:
CPU: Intel Xeon E5620 @ 2.40GHz x2
Ram: 24.0 GB Triple-Channel DDR3 @532MHz (7-7-7-20)
Motherboard: EVGA EVGA Classified SR-2
GPU: GTX 1070 x2 and TITAN Black x2
Storage: 256GB SSD Samsung 850 PRO
Power - 1500W
I have cleaned and replaced the the thermal paste. Nothing is overheating.
1) Am i running the wrong version of Octane? 3.04.4.5
2) Am i running the wrong Sketchup? I am using 2015 because I don't think the new 2017 will work with my GTX1070's?
3) Should i get rid of the GTX1070's and go with something else? (i just bought them)
4) Should i use the Cloud rendering and let them do the heavy lifting?
ugh... Do i need to go with a new motherboard and cpus?
Please help!
WK
[email protected]
lcp360
Re: Need Help - Octane Freezes using Google Sketchup 2015
Postby lcp360 » Sat Feb 18, 2017 3:26 am
lcp360 Sat Feb 18, 2017 3:26 am
I'm also running Windows 10 64bit
My Octane version is 2.X - Should i upgrade to 3.X?
lcp360
Postby lcp360 » Sat Feb 18, 2017 3:28 am
lcp360 Sat Feb 18, 2017 3:28 am
actually I have:
Octane Render Standalone 2 licenses:
1) 2.X
2) 3.X
Octane Sketchup Plugin
1) 3.X
2) 3.X
lcp360
Postby smicha » Sat Feb 18, 2017 9:42 am
smicha Sat Feb 18, 2017 9:42 am
It is about win10 bug with 100% disk usage problem.
Try this :
1. Edit registry for prefetcher - set 1 instead of 3 (run regedit -> local machine -> system -> control set ->control->session manager->mem.manag.->prefetch...)
2. Kill the services: windows search, superfetch, connected use experiences and telemetry, background intelligent transfer service
3. turn off flash in chrome entering url -> chrome://plugins
Hope it helps,
s
smicha
Postby lcp360 » Sat Feb 18, 2017 7:37 pm
lcp360 Sat Feb 18, 2017 7:37 pm
#smicha
Thank you for the advice. I have disabled the items you mentioned, updated the CUDA, and updated the NVIDIA Graphics drivers...
Unfortunately this did not work for me..
WK
lcp360
Postby lcp360 » Sat Feb 18, 2017 9:18 pm
lcp360 Sat Feb 18, 2017 9:18 pm
After some further tests octane does initiate and work however it takes 3-5 minutes for it to initiate. On some larger models it crashes after running for a few minutes. I have videos available of this if necessary. In the end it works but very very slow to load. Is it my old processors causing this??
lcp360
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 37 guests
Fri Apr 26, 2024 10:50 pm [ UTC ]
