by areyal » Fri Mar 18, 2011 8:09 am
areyal
Yes, I suppose it would be a problem to make it consistent.
Later I realised in octane you can actually rename de inputs ONLY during the first import if you haven't assigned external materials to the mesh trough the inputs.
BUT, as Kubo says, it may be a problem if you update the mesh with the modelling app.
I've not tried it, but I suppose in the updated mesh, the old renamed input would dissapear and instead appear a new one with a new name, so would be better to make it right in the modelling app (if it's possible...) I'll check it arround in MAX
GPU GTX 480 / GT 430 for UI
CPU Intel Core 2 Quad Q8300 (2.5 Ghz) / RAM 8 GB DDR2
SOFT Windows 7 64bit4
