how to stagger a texture
Forums: how to stagger a texture
Postby AndreasBergmann » Wed Sep 27, 2023 3:40 pm
AndreasBergmann Wed Sep 27, 2023 3:40 pm
looked in forum but couldn't find any answer to this. How do you stagger an image texture in octane?
Thanks for any advice, Andreas
AndreasBergmann
Re: how to stagger a texture
Postby bepeg4d » Thu Sep 28, 2023 6:55 am
bepeg4d Thu Sep 28, 2023 6:55 am
Hi Andreas,
not sure to have understood your question correctly (always better to post some screenshots), but please, have a look at Chaos texture node here:
https://docs.otoy.com/StandaloneH_STA/S ... ight=chaos
ciao,
Beppe
Postby AndreasBergmann » Fri Sep 29, 2023 8:03 am
AndreasBergmann Fri Sep 29, 2023 8:03 am
Thanks for your reply,
I am talking about a tiling with offset in the next row, like a brick tiling instaed of square grid tiling. Best would be to set a value for the offset. Every once in a while I get a pattern with offset.
Thanks, Andreas
AndreasBergmann
Postby jobigoud » Fri Sep 29, 2023 1:05 pm
jobigoud Fri Sep 29, 2023 1:05 pm
I played a bit with a square wave plugged into distorted UV projection. The square wave creates horizontal stripes with low/high values and this drives the horizontal translation of the UV.
I had to tweak it to find the right alignment. Maybe you can play with it until you find the correct setup for your texture. In the wave pattern tweak the amplitude, scaling and position and in the distorted UV node you can also play with the translation range.
stagger-test.orbx
(512.99 KiB) Downloaded 64 times
jobigoud
Postby AndreasBergmann » Fri Oct 06, 2023 7:35 am
AndreasBergmann Fri Oct 06, 2023 7:35 am
Thanks a lot!! This is a workaround, had to do some tests to find settings for scaling & shifting of tiles & pattern and worked better with box projection in wave pattern.
AndreasBergmann
Return to General Discussion
Users browsing this forum: No registered users and 14 guests
Thu Jun 06, 2024 12:52 pm [ UTC ]
