Same Mesh, Same Material, Different Result??
Forums: Same Mesh, Same Material, Different Result??
Postby botoy234 » Sun Jun 04, 2023 7:37 pm
botoy234 Sun Jun 04, 2023 7:37 pm
This is driving me up the wall...
I export and re-import a model into C4D without making any changes to it, apply the same material, same phong tag, same mesh no changes...but one of the meshes reflects properly, and the other doesn't. What is happening?
Here are the same mesh side by side. What is happening?
https://postimg.cc/8j0hVFbk
botoy234
Re: Same Mesh, Same Material, Different Result??
Postby botoy234 » Sun Jun 04, 2023 10:02 pm
botoy234 Sun Jun 04, 2023 10:02 pm
More information: I think it has something to do with temporarily stored UV's or vertex order that gets changed when it exports and reimports back in?
I noticed that the normal map is m apping wrong and was distorting the reflection, which explains why the surface looks smooth in profile, but the reflection is bumpy..but it makes no sense since it's the same model, had no UV map, nothing was touched, etc. ..I don't understand why it would map the normal map differently just from exporting the model as .obj and importing it again?
botoy234
Postby bepeg4d » Mon Jun 05, 2023 6:12 am
bepeg4d Mon Jun 05, 2023 6:12 am
do you have a c4d Normal tag on the imported .obj?
If yes, try to delete it, and double check the Phong tag.
ciao,
Beppe
Postby elsksa » Mon Jun 05, 2023 4:15 pm
elsksa Mon Jun 05, 2023 4:15 pm
botoy234 wrote:(...) just from exporting the model as .obj and importing it again?
Alembic is strongly recommended and a "worldwide standard".
elsksa
Return to General Discussion
Users browsing this forum: No registered users and 23 guests
Fri Apr 26, 2024 7:01 pm [ UTC ]
