falloff map node request
Forums: falloff map node request
Sub forum for feature requests etc
Moderator: aoktar
Postby 3dworks » Wed Aug 07, 2019 6:37 pm
3dworks Wed Aug 07, 2019 6:37 pm
please would it be possible to make the minimum for the "falloff skew factor" much to less than 0.1? currently it is limited to that.
i'm using this node as seen in the screenshot for the known "fake spotlight" effect, but to get a sharper transition for the borders of the light cone, this factor needs to be set to a much lower value like 0.01 and less. i've used this trick a lot in lightwave but in cinema with this limitation it only gives a quite soft result...
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
3dworks
Return to User requests
Fri Apr 26, 2024 8:11 pm [ UTC ]
