Lens effects causes render failure
Forums: Lens effects causes render failure
Sub forum for bug reports
Moderator: aoktar
C. RAM Capacity (i.e. 6 GB)
Postby LA59494 » Tue Apr 23, 2024 3:50 pm
LA59494 Tue Apr 23, 2024 3:50 pm
Hi there,
I found that the lens effect features (Chromatic aberration or lens flare intensity) causes a render failure if higher than 0. When I reset it to 0 the LV/Render will work normal again.
Post Processing works normal. Running the latest MacOS Standalone and the latest stable C4D Plugin on my Macbook M2 Max (on 13.6).
Lars
LA59494
Re: Lens effects causes render failure
Postby bepeg4d » Wed Apr 24, 2024 6:27 am
bepeg4d Wed Apr 24, 2024 6:27 am
Hi Lars,
sorry but I cannot reproduce the issue here on macOS with latest 2023.1.3 stable version, both Chromatic Aberration and Lens Flare are working as expected in both Live View and Picture Viewer:
Please go to c4d menu Extensions/Console, (Shift+F10), and share a complete screenshot of the panel, or copy paste the default console output in your answer, thanks.
ciao,
Beppe
Postby LA59494 » Wed Apr 24, 2024 6:48 am
LA59494 Wed Apr 24, 2024 6:48 am
Hi Beppe,
here's my console. I tried to resend it three times. Every time the console and log pops up.
Loaded Octane DLL:Octane X Prime 2023.1.2  version:13000200  SDK:2023.1.2
Octane X for Cinema 4D 2023.1.2-[R7]  built for:20230   C4D vers:2023200
C4D:2023200  comp:[Lars’ MacBook Pro]  OS:[OS X 64 BIT] macOS: Version 13.6 (Build 22G120)  versType:10
CPU:[]  speed:0 GHz  numOfCpu:12
Plugins:[addons advanced_render alembic analytics archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_emulation c4d_viewport_render c4dOctane-R2023 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair i_skp interop interop_forger io_forger io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor2 objects pbd_simulations physx_hybrid projectassetinspector python redshift relaxuv scenemanager2 sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking_particles tool_system_hybrid tpoperators usd uvviewport volumes xpressocore xtensions redshift4c4d ]
Loaded 175 osl scripts from dir:/Applications/Maxon Cinema 4D 2023/plugins/OctaneRender/res/osl_scripts
initOCIOconfig     cfgFile:    OCIO_ENV:
VRAM used/free/max:0Kb/32Gb/32Gb  Out-of-core used:0Kb  RAM used:20.03Gb total:32Gb  OpenGL free/total:0/0
Export materials time= 0.032 ms
Collect objects time= 0.022 ms
Mesh creation time = 1.006 ms.
Api update time: 0.022 ms.
VRAM used/free/max:1.252Gb/30.748Gb/32Gb  Out-of-core used:0Kb  RAM used:20.37Gb total:32Gb  OpenGL free/total:0/0
File not found:/Users/larsallenberg/Library/Preferences/Maxon/Maxon Cinema 4D 2023_3BE69839/updates2020.txt
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
 MB:0/0  ST/MOV:0/0  Nodes:13  Tris:0  DispTris:0  Hairs:0  Meshes:1
OCT: MB:0/0  ST/MOV:0/0  Nodes:13  Tris:0  DispTris:0  Hairs:0  Meshes:1
 Textures Grey8/16:0/0  Rgb32/64:0/0
OCT: Textures Grey8/16:0/0  Rgb32/64:0/0
>> ProcessUpdate(flags=CM cAsyn=1 dDelay=1
>> ProcessUpdate end res:0 tm:0.004ms.
OCT:--------------------------- EXPORT LOG ---------------------------
ResetAndInit 1
ResetAndInit [OK]
Export materials time= 0.018 ms
Collect objects time= 0.012 ms
Mesh creation time = 0.217 ms.
Api update time: 0.025 ms.
 MB:0/0  ST/MOV:0/0  Nodes:12  Tris:0  DispTris:0  Hairs:0  Meshes:1
OCT: MB:0/0  ST/MOV:0/0  Nodes:12  Tris:0  DispTris:0  Hairs:0  Meshes:1
ResetAndInit 1
ResetAndInit [OK]
Export materials time= 0.019 ms
Collect objects time= 0.013 ms
Mesh creation time = 0.535 ms.
Api update time: 0.014 ms.
Lars
Screenshot
LA59494
Postby bepeg4d » Thu Apr 25, 2024 6:34 am
bepeg4d Thu Apr 25, 2024 6:34 am
Hi Lars,
ok, please also share a screenshot like this one, that shows both c4doctane directory opened, and the entire installation path, thanks:
ciao,
Beppe
Postby LA59494 » Thu Apr 25, 2024 11:02 am
LA59494 Thu Apr 25, 2024 11:02 am
Hi Beppe,
this looks pretty much the same. Only difference is I renamed the folder to "OctaneRender" to shorten the long default name in the C4D extensions. But I handled it before like that and lens flare was working.
Best,
Lars
Finder
LA59494
Postby bepeg4d » Mon Apr 29, 2024 7:33 am
bepeg4d Mon Apr 29, 2024 7:33 am
Hi Lars,
ok, please close C4D, then change the name of the folder from "Plugins" to "plugins" in lowercase:
ciao,
Beppe
Postby LA59494 » Tue Apr 30, 2024 10:52 am
LA59494 Tue Apr 30, 2024 10:52 am
Hi Beppe,
changed the folder name but no difference. Been on 2023.1.2-R7 when posting this thread and updated to 2023.1.3-R2 today but the issue is still present. Think I have been on 2023.1.2-R3 before R7 and will go back for now.
Lars
LA59494
Postby bepeg4d » Tue Apr 30, 2024 11:01 am
bepeg4d Tue Apr 30, 2024 11:01 am
Weird, I cannot reproduce the issue with both 2023.1.2-R7 and 2023.1.3-R2.
Ok, please write to help at otoy dot com asking for Beppe, thanks.
ciao,
Beppe
Postby LA59494 » Tue Apr 30, 2024 12:43 pm
LA59494 Tue Apr 30, 2024 12:43 pm
Hi Beppe,
Ricky reached out to me and we figured what's going on. When the LVs resolution is odd (non-power of 2) there will be a render failure when lens features are used. When I lock the resolution to an even number it works fine.
Best,
Lars
LA59494
Postby bepeg4d » Tue Apr 30, 2024 2:54 pm
bepeg4d Tue Apr 30, 2024 2:54 pm
Hi Lars,
yes, it is a core issue, great that Ricky found it out!
ciao,
Beppe
Return to Bug Reports
Mon May 06, 2024 8:01 am [ UTC ]
