Cinema4D version 2023.1.2-[R7] (Obsolete stable) 27.03.2024
Forums: Cinema4D version 2023.1.2-[R7] (Obsolete stable) 27.03.2024
Moderator: aoktar
Re: Cinema4D version 2023.1.2-[R7] (Latest stable) 27.03.2024
Postby Anlv » Fri Mar 29, 2024 2:59 am
Anlv Fri Mar 29, 2024 2:59 am
eyeonestudio wrote:Octane Not Loading My Notebooke(eGPU 3090)
R6 is OK.
C4D console.....
CRITICAL: Method net.maxon.interface.assetlink.Create@874ec4c6e3a0aae not implemented by AssetLinkImpl (requested by file:///C:/Program Files/MAXON/CINEMA 4D 2024.2.0/plugins/c4doctane/c4dOctane-R2024.xdl64). [object_impl.cpp(908)] [objectbase1.hxx(537)]
net.maxon.asset.framework: Initialization of net.maxon.interface.assetlink [interface] failed.
CRITICAL: Method net.maxon.node.interface.nodeslib.CreateTemplateFromNodeSystem@3e4a2e59c095eb1a not implemented by NodesLibImpl (requested by file:///C:/Program Files/MAXON/CINEMA 4D 2024.2.0/plugins/c4doctane/c4dOctane-R2024.xdl64). [object_impl.cpp(908)] [objectbase1.hxx(537)]
net.maxon.nodes.framework: Initialization of net.maxon.node.interface.nodeslib [interface] failed.
Drawport API initialized
Framework : DirectX
Vendor : NVIDIA
Device : NVIDIA GeForce RTX 3090
Framework version: 12
WIN10 21H1 19043.1165
Processor Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz 2.20 GHz
Installed RAM 32.0 GB (31.9 GB usable)
R7 version requires Cinema 4D 2024.3.2.
3D Motion Graphics Designer / E-commerce Designer
13700K / 64GB / 4090 / PSU 1250W
Anlv
Postby eyeonestudio » Fri Mar 29, 2024 3:45 am
eyeonestudio Fri Mar 29, 2024 3:45 am
I didn't see the instructions on the first page. Thanks. I will test with 2024.3.2.
I don't like C4D's repeated changes. Virtualization is unstable.
CINEMA 4D R2023
Win10 / 10GbE / AMD3995X*2ea, AMD3990X*2ea, 10980XE*2ea / 256Gb RAM / RTX3090*14ea
eyeonestudio
Postby SSmolak » Sat Mar 30, 2024 1:08 pm
SSmolak Sat Mar 30, 2024 1:08 pm
Can you add input selection to Switch node input pins ?
SSmolak
Postby scaprendering » Sat Mar 30, 2024 3:00 pm
scaprendering Sat Mar 30, 2024 3:00 pm
Vectron operators between mesh to SDF and vectron is being overridden by original mesh to SDF.
[youtube]https://youtu.be/JiTKmSBXDrA[/youtube]
@Ahmet can you please have a look ? This feature would be awesome and unique. :)
SDFBoole.zip
(82.46 KiB) Downloaded 10 times
scaprendering
Postby SSmolak » Sat Mar 30, 2024 4:29 pm
SSmolak Sat Mar 30, 2024 4:29 pm
LOD Convex Hull simplify display mode is transparent in Octane :
LOD_hull.zip
(322.76 KiB) Downloaded 12 times
SSmolak
Postby aoktar » Sat Mar 30, 2024 7:40 pm
aoktar Sat Mar 30, 2024 7:40 pm
SSmolak wrote:LOD Convex Hull simplify display mode is transparent in Octane :
scene?
Postby aoktar » Sat Mar 30, 2024 8:07 pm
aoktar Sat Mar 30, 2024 8:07 pm
scaprendering wrote:Vectron operators between mesh to SDF and vectron is being overridden by original mesh to SDF.
SDFBoole.zip
Voxel size of mesh_sdf is affecting the vectron. It's happening in SA also, so ask in SA forums.
Postby SSmolak » Sat Mar 30, 2024 8:14 pm
SSmolak Sat Mar 30, 2024 8:14 pm
Undo in node editor doesn't work if texture is dragged directly to image texture node. It works fine if texture is dragged to "edit controls" panel.
It switch to previous material in material manager instead.
node_undo.zip
(299.41 KiB) Downloaded 11 times
SSmolak
Postby SSmolak » Sat Mar 30, 2024 8:33 pm
SSmolak Sat Mar 30, 2024 8:33 pm
scene?
It looks that this is caused by UV opacity texture that doesn't work on Convex Hull custonm object :
LOD_0001.zip
(181.18 KiB) Downloaded 9 times
SSmolak
Postby scaprendering » Mon Apr 01, 2024 10:23 am
scaprendering Mon Apr 01, 2024 10:23 am
In standalone it works great, but in C4D the issue is that the SDF is being displayed twice, before the boole and after the boole.
Once the SDF has been booled, it should no connect back to group_1:
Expected Behavior: After applying the boolean operation (intersection or subtraction), only the resultant mesh (the modified SDF) should be visible in the render.
Actual Behavior: The original mesh SDF remains visible in the final render alongside the boolean result, leading to an incorrect visual outcome where both the original and modified meshes overlap.
This issue seems to be a bug as the expectation with boolean operations is to only display the modified mesh resulting from the operation, not the original unmodified mesh. It can be fixed by opening Octane node graph and manually disconnect the volume SDF fo group_01 but when Octane updates the scene it reconnects back.
scaprendering
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 8 guests
Sun Apr 28, 2024 10:48 am [ UTC ]
