I am trying to make a laser beam, with a really thin gobo but it gets really noisy.
All assets are attached.
Moderator: aoktar
marcus1070 wrote:Hi, I've posted about the chaos node being broken, but it's not, actually the problem is happening from an osl strange behaviour.
I had some include directories on the paths config, and that was causing all osl shaders to not compile. Then i removed the paths and it worked, but...
Using a different OSLs scripts location option, it only works the original octane osls, the other ones doesn't load up, when you drag and drop, the add osl comes up, the only way to add different osls now is to copy them to c4d plugin osl folder and use the default folder, that way it reads.
crazy stuff
Users browsing this forum: No registered users and 17 guests
