Cinema4D version 2022.1-RC2 19.11.2022
Forums: Cinema4D version 2022.1-RC2 19.11.2022
Moderator: aoktar
Re: Cinema4D version 2022.1-RC2 19.11.2022
Postby SSmolak » Tue Nov 22, 2022 4:33 pm
SSmolak Tue Nov 22, 2022 4:33 pm
Creating XRef from C4D database doesn't fully work because Octane doesn't read materials from database.
Render All Matertials in Material Editor doesn't work
SSmolak
Postby aoktar » Tue Nov 22, 2022 4:37 pm
aoktar Tue Nov 22, 2022 4:37 pm
SSmolak wrote:Creating XRef from C4D database doesn't fully work because Octane doesn't read materials from database.
Please don't make your reports without projects.
Postby SSmolak » Tue Nov 22, 2022 4:54 pm
SSmolak Tue Nov 22, 2022 4:54 pm
aoktar wrote:Please don't make your reports without projects.
Project :
It also doesn't work if we put to browser objects with Octane materials.
Generally XRef's works fine but not if it is loaded from browser with materials/images stored within it.
EDIT : ok it works but it is little tricky. Octane needs to XRef by stored in Asset Browser as regular XRef object referenced to orginal one. So there is need to prepare it and after that it can be stored in browser... This is time consuming if we need more objects to be XRef'ed for further use in projects.
Using regular XRef's I had today tens of freezes and crashes :(
Generate objects preview in Asset Browser using Octane doesn't work but generating scene preview works fine - I know that there is bug because C4D needs to create preview while adding object to database ( generating doesn't work after that ) but anyway using Octane renderer for objects never works.
Octane_XRef.zip
(239.6 KiB) Downloaded 87 times
SSmolak
Postby m2001 » Thu Nov 24, 2022 12:47 am
m2001 Thu Nov 24, 2022 12:47 am
aoktar wrote:
SSmolak wrote:
m2001 wrote:Bug?
Changes in Octane Environment Tag (with a HDRI Image) e.g. Parameter RotX & RotY doesn't update the octane live viewer.
I have to reload the full scene in live viewer, to see changes.
But, e.g. the Parameter "Power" updates the live viewer immediately.
Cinema 4D 2023.1
Works fine. Probably you have additional node between image texture and environment tag.
Yes, plugin cannot modify the complex internal structures for you. You have to translate the images by hand in these cases
Note:
With RC3
viewtopic.php?f=85&t=80809
and without any changens in the scene/environment Tag, RotX & RotY works again. Live viewer updates immediately.
m2001
Previous
Return to Releases
Users browsing this forum: No registered users and 11 guests
Wed May 08, 2024 11:58 pm [ UTC ]
