it seems that you have only ~4.5GB of VRAM available, so at least you can load less than ~20M polys, try to use Out-of-core geometry, if you have enough RAM.
ciao Beppe
Moderator: aoktar
bepeg4d wrote:Hi,
ciao Beppe
stefano-dear wrote:aoktar wrote:stefano-dear wrote:I also found this problem with network rendering:
Launching net render slave (4000017) with master 10...
unpacked file image has unexpected type
didn't receive all required images from master
invalid message received from network connection
slave crashed or was stopped via CTRL-C
reached the maximum number of consecutive runs of a slave (5) -> bailing out
artdude12 wrote:I'm getting an error message that says this version is no longer supported and cannot be activated.
4.05 Stand Alone is running with no errors. What is the problem with the plugin?
Users browsing this forum: Google [Bot] and 9 guests
