Moderator: aoktar
marshalartist wrote:There is a problem with the Octane gradient node. It turns everything red that is fed into it when adjusted. Please see attached file
Amaterasu wrote:Where can I find the manual.zip? I uninstalled all versions except 2024 and for some reason the octane did not appear, but on cinema 4D R26 everything works, I had the same problem with the stable build
Amaterasu wrote:Update
aoktar wrote:Amaterasu wrote:Update
Double check your install for double installs which causes . You looks like running previous build:(2023.1.2). Also try latest Nvidia drivers
