Cinema4D version 2023.1.3-R2 (Latest stable) 24.04.2024
Forums: Cinema4D version 2023.1.3-R2 (Latest stable) 24.04.2024
Moderator: aoktar
Re: Cinema4D version 2023.1.3 (Latest stable) 19.04.2024
Postby marshalartist » Tue Apr 23, 2024 8:50 am
marshalartist Tue Apr 23, 2024 8:50 am
There is a problem with the Octane gradient node. It turns everything red that is fed into it when adjusted. Please see attached file
gradient.zip
(96.48 KiB) Downloaded 8 times
marshalartist
Postby frankmci » Tue Apr 23, 2024 3:54 pm
frankmci Tue Apr 23, 2024 3:54 pm
marshalartist wrote:There is a problem with the Octane gradient node. It turns everything red that is fed into it when adjusted. Please see attached file
It looks like the Octane Gradient node is behaving as if there is an "invisible" red color chip on the left edge of the gradient and an invisible white node on the right. As a workaround for the moment, you can add a color chip to the far left and right, then it should work as expected.
Gradient bug work-around
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby aoktar » Wed Apr 24, 2024 10:33 am
aoktar Wed Apr 24, 2024 10:33 am
It's a BUG because of my latest revisions. It is fixed on R2 build.
Re: Cinema4D version 2023.1.3-R2 (Latest stable) 24.04.2024
Postby Amaterasu » Thu Apr 25, 2024 2:20 am
Amaterasu Thu Apr 25, 2024 2:20 am
How to fix the problem?
octane 2023.1.2 240425 052006.txt
(14.99 KiB) Downloaded 8 times
Amaterasu
Postby Amaterasu » Thu Apr 25, 2024 2:23 am
Amaterasu Thu Apr 25, 2024 2:23 am
Where can I find the manual.zip? I uninstalled all versions except 2024 and for some reason the octane did not appear, but on cinema 4D R26 everything works, I had the same problem with the stable build
Amaterasu
Postby Amaterasu » Thu Apr 25, 2024 2:26 am
Amaterasu Thu Apr 25, 2024 2:26 am
Update
octane 2023.1.2 240425 052539.txt
(3.31 KiB) Downloaded 7 times
Amaterasu
Postby SSmolak » Thu Apr 25, 2024 2:37 am
SSmolak Thu Apr 25, 2024 2:37 am
Amaterasu wrote:Where can I find the manual.zip? I uninstalled all versions except 2024 and for some reason the octane did not appear, but on cinema 4D R26 everything works, I had the same problem with the stable build
Delete C:\Users\ YOUR USER NAME \ AppData\Roaming\Maxon\Maxon Cinema 4D 2024_A5DBFF93\prefs oct.dat file. and install Octane again. Last builds are for 2024 C4D version.
SSmolak
Postby aoktar » Thu Apr 25, 2024 7:22 am
aoktar Thu Apr 25, 2024 7:22 am
Amaterasu wrote:Update
Double check your install for double installs which causes . You looks like running previous build:(2023.1.2). Also try latest Nvidia drivers
Postby Amaterasu » Thu Apr 25, 2024 1:55 pm
Amaterasu Thu Apr 25, 2024 1:55 pm
Yes, that's right because the latest version is simply not installed, I tried to do all the above points and it is on cinema 4d 2024.3.2 the latest version of octane is not installed, on cinema 4d R26 all stood up without problems.
The error did not go anywhere, I attach the log from cinema 4d R26 + octane 2023.1.3-[R2], thank you for your help!
octane 2023.1.3 240425 165513.txt
(4.74 KiB) Downloaded 10 times
Amaterasu
Postby stefano-dear » Fri May 03, 2024 8:26 am
stefano-dear Fri May 03, 2024 8:26 am
with old files the live viewer works correctly, but if I launch in render it always crashes :(
c4doctanelog[1].txt
(19.21 KiB) Downloaded 4 times
stefano-dear
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 16 guests
Mon May 06, 2024 8:02 am [ UTC ]
