Cinema4D 2022.1-[R10] (Previous stable) (26.03.2023)
Forums: Cinema4D 2022.1-[R10] (Previous stable) (26.03.2023)
Moderator: aoktar
Re: Cinema4D 2022.1 (Latest stable) (19.11.2022)
Postby aoktar » Mon Dec 05, 2022 11:51 am
aoktar Mon Dec 05, 2022 11:51 am
AaronWestwood wrote:
Totally understand. It is urgent, purely as I would love to start using the wonderful features of 2022 for a job im on as it would elevate what I can do, but cant as its 100% scatter dependent.
How long would a fix take/the other fixes take? Is a new version days/weeks out?
Thanks for the reply.
Can't give exact timing. Depends to success of our progress on addon and fixes. Maybe in a few days. Btw you can easily work-around it. For example disconnect effector then delete it.
Postby AaronWestwood » Mon Dec 05, 2022 12:00 pm
AaronWestwood Mon Dec 05, 2022 12:00 pm
A few days is totally fine. Will keep an eye out.
I have a ton of scatters connected to dozens of effectors that im tweaking/changing so disconnecting/reconnecting is so out of habit that I find myself crashing by accidently deleting. User error navigating this "fix" for sure. Will stay in 2021 until the fix is ready.
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
AaronWestwood
Postby azumbrunnen » Tue Dec 06, 2022 4:04 pm
azumbrunnen Tue Dec 06, 2022 4:04 pm
I'm using this version on a render farm with Windows. Is this fully interchangeable? I sometimes get strange render artifacts and vdb's not loading correctly.
azumbrunnen
Postby aoktar » Tue Dec 06, 2022 4:27 pm
aoktar Tue Dec 06, 2022 4:27 pm
azumbrunnen wrote:I'm using this version on a render farm with Windows. Is this fully interchangeable? I sometimes get strange render artifacts and vdb's not loading correctly.
can you contribute more about issues?
Postby azumbrunnen » Tue Dec 06, 2022 5:20 pm
azumbrunnen Tue Dec 06, 2022 5:20 pm
Yes VDB loader often has repeating frames. I.e. it just shows the same frame 3 times in a row instead of properly loading the next VDB. It's completely random though and it's not reproduceable. When I re-render, the next time it happens on other frame ranges.
azumbrunnen
Postby Kalua » Tue Dec 06, 2022 5:40 pm
Kalua Tue Dec 06, 2022 5:40 pm
Plugin is working great, Aoktar! Thanks!
Not sure anyone reported it yet:
Gradient on complex mode is not updating the node pins, wheter it's new gradient node or an already existing complex gradient where I am eliminating values.
Sometimes it updates, sometimes it doesn't.
Pins not appearing or being removed
C4D 25.117 Octane 2022.1.2 R4, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 536.67
Kalua
Postby aoktar » Tue Dec 06, 2022 9:02 pm
aoktar Tue Dec 06, 2022 9:02 pm
Kalua wrote:Plugin is working great, Aoktar! Thanks!
Ok I'm checking it, not reproduced yet but thanks! You can press to "Get active material" as work-around. Sending a sample scene may help to see the issue
Postby Kalua » Wed Dec 07, 2022 11:08 pm
Kalua Wed Dec 07, 2022 11:08 pm
Thank you. If I find a consistent reproduceable scene I will send you.
Regards,
Kalua
Postby SSmolak » Thu Dec 08, 2022 1:30 am
SSmolak Thu Dec 08, 2022 1:30 am
Octane Texture Manager can't find any of the missing HDRI maps from Octane Sky Object. It even not shows them if they are propely linked. It doesn't accept relinks from C4D Project Asset Inspector.
I noticed this months ago but working now with larger scene this is more noticeable - Octane sometimes when operations take little longer automatically switch to 2x2 subsampling mode and stay with it until manually it will not disabled. I have set Perf.timer to 1000. Is this really needed ?
Material Layer for Standard Surface doesn't work right ?
SSmolak
Postby freeter_e » Sat Dec 10, 2022 9:02 am
freeter_e Sat Dec 10, 2022 9:02 am
modify multiple material colors
matertial preview, not refresh
i test on v2021.1.4-R4,it's ok
on v2021.1.6-R6,v2022.1,it noesn't work
freeter_e
PreviousNext
Return to Releases
Fri Apr 26, 2024 1:32 am [ UTC ]
