Cinema4D version 2021.1.7 (Old stable) 16.12.2022
Forums: Cinema4D version 2021.1.7 (Old stable) 16.12.2022
Moderator: aoktar
Re: Cinema4D version 2021.1.6-(R4) (Latest stable) 18.09.2022
Postby stefano-dear » Wed Sep 28, 2022 11:06 am
stefano-dear Wed Sep 28, 2022 11:06 am
aoktar wrote:
stefano-dear wrote:I also tried version 2021.1.6 but it still crashes. I only have one texture displacement
It's looks like your geometries or vertex displacement. Having one displacement doesn't mean that will not crash. It's possible if you go high on tessellation.
It seems strange to me because the surface with dispacement is very small and the resolution is only set to 1024.
In attached two other crash reports if could helps
bugreport_20220928_130342.zip
(1.91 KiB) Downloaded 70 times
bugreport_20220928_123243.zip
(3.4 KiB) Downloaded 63 times
stefano-dear
Postby aoktar » Wed Sep 28, 2022 12:15 pm
aoktar Wed Sep 28, 2022 12:15 pm
stefano-dear wrote:It seems strange to me because the surface with dispacement is very small and the resolution is only set to 1024.
These are not bugreports with crashes. Better to contact to support with your scene and details about errors.
Postby Torquee » Wed Sep 28, 2022 4:32 pm
Torquee Wed Sep 28, 2022 4:32 pm
Hi Ahmet/Team,
Having endless crashes with a project when starting Live Viewer and after I add another material to an object with a polygon selection it will crash every time.
Cinema 4D R26.107
Octane plugin 2021.1.6-R4-win
RTX 3090 24Gb
Titan Xp 12Gb
Attaching crash reports. Any direct clues on what is going on?
Please be gentle, I am new to PC ;)
Grateful for a solution as work is now halted.
220928_2 octane 2021.1.6 220921 130320.txt
(201.63 KiB) Downloaded 65 times
220928_1 octane 2021.1.6 220921 130320.txt
(101 KiB) Downloaded 62 times
Torquee
Postby jayroth2020 » Wed Sep 28, 2022 7:25 pm
jayroth2020 Wed Sep 28, 2022 7:25 pm
@Torquee, please file a support ticket at [email protected] and include your scene and associated textures. Do this via File > Save Project As... — archive the result and send it in.
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 1 EVGA RTX 3090Ti FTW3 Hybrid / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
jayroth2020
Postby Torquee » Wed Sep 28, 2022 8:09 pm
Torquee Wed Sep 28, 2022 8:09 pm
jayroth2020 wrote:@Torquee, please file a support ticket at [email protected] and include your scene and associated textures. Do this via File > Save Project As... — archive the result and send it in.
Many thanks!
Torquee
Postby Delizade » Wed Sep 28, 2022 9:38 pm
Delizade Wed Sep 28, 2022 9:38 pm
hi,
I can't solo sub nodes of a mix material.
mixMaterialSoloNodeProblem.zip
(175.21 KiB) Downloaded 60 times
Windows 10 (3090Ti) | MacBook Pro (M3 Max)
Delizade
Postby bepeg4d » Thu Sep 29, 2022 6:04 am
bepeg4d Thu Sep 29, 2022 6:04 am
Delizade wrote:hi,
Try to convert the Mix Material into a Composite Material, by going in Live View menu Materials/Convert material command.
Mix Material has several limitations, always better to use a Composite Material instead.
ciao,
Beppe
Postby Delizade » Thu Sep 29, 2022 11:20 pm
Delizade Thu Sep 29, 2022 11:20 pm
bepeg4d wrote:
Delizade wrote:hi,
ciao,
Beppe
Solo node feature does not work on Mix material as well.
I can't make tests right now but currently I can't view solo nodes.
I will try to make some tests another time for this issue, I don't know it is happening for me or it is caused by plugin I'm not sure.
Delizade
Postby jayroth2020 » Thu Sep 29, 2022 11:28 pm
jayroth2020 Thu Sep 29, 2022 11:28 pm
Mix Material is essentially deprecated. I would not expect to see any changes in that regard.
jayroth2020
Postby Kalua » Sun Oct 02, 2022 1:55 pm
Kalua Sun Oct 02, 2022 1:55 pm
jayroth2020 wrote:Mix Material is essentially deprecated. I would not expect to see any changes in that regard.
Any plans to get rid of MIX materials?
Hope not since I find good to have different options for different workflows scenarios.
C4D 25.117 Octane 2022.1.2 R4, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 536.67
Kalua
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 13 guests
Fri Apr 26, 2024 5:57 am [ UTC ]
