Cinema4D version 2022.1-XB1-(R3) (Experimental) 02.06.2022
Forums: Cinema4D version 2022.1-XB1-(R3) (Experimental) 02.06.2022
Moderator: aoktar
Re: Cinema4D version 2022.1-XB1-(R2) (Experimental) 26.05.2022
Postby aoktar » Sat May 28, 2022 8:44 pm
aoktar Sat May 28, 2022 8:44 pm
SSmolak wrote:
aoktar wrote:
SSmolak wrote:Changing Layered Material type to different one like Diffuse doesn't work. Only way is to create new material from scratch.
Not sure what are you showing and how you can see this menu command. It's not appearing on sub materials. And deleting/creating is not only way to change the type. See pic.
I mean Octane Composite. I thought that this menu is to convert it to something else ( not layered one ). I have old material with which is layered that now can be done using Octane UIniversal but I see that there is no way to simple convert or change it to Universal one.
Why don't you just use the "material type" for that?
Postby aoktar » Sat May 28, 2022 9:08 pm
aoktar Sat May 28, 2022 9:08 pm
SSmolak wrote:Undo doesn't work if node is still selected after changing parameter while using embedded GUI
It's not as you said. Selected GUI is avoiding to capture shortcut call for undo. Try without selecting the node, it will work. I'll fix this problem.
Postby SSmolak » Sun May 29, 2022 1:20 am
SSmolak Sun May 29, 2022 1:20 am
aoktar wrote:Why don't you just use the "material type" for that?
even if I change it here for sub-material it still be layered one :
I can change only sub not main.
SSmolak
Postby SSmolak » Mon May 30, 2022 4:42 pm
SSmolak Mon May 30, 2022 4:42 pm
Opening Octane Texture Manager in scenes with many images like 270 cause freeze or stuttering for minute.
Opening Node Editor for first time it always get 2/3 of whole screen size.
SSmolak
Postby aoktar » Mon May 30, 2022 8:33 pm
aoktar Mon May 30, 2022 8:33 pm
SSmolak wrote:Opening Octane Texture Manager in scenes with many images like 270 cause freeze or stuttering for minute.
Share the project and a video for the issue! It should not hold the main soft, it's not doing it in main loop.
Re: Cinema4D version 2022.1-XB1-(R3) (Experimental) 02.06.2022
Postby Kalua » Thu Jun 02, 2022 4:52 am
Kalua Thu Jun 02, 2022 4:52 am
I can't download Enterprise R3... am I missing something?
C4D 25.117 Octane 2022.1.2 R4, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 536.67
Kalua
Postby aoktar » Thu Jun 02, 2022 9:31 am
aoktar Thu Jun 02, 2022 9:31 am
Kalua wrote:I can't download Enterprise R3... am I missing something?
File was deleted by mistake, replaced it again. Sorry for that!
Postby Tim_Twisted » Thu Jun 02, 2022 9:45 am
Tim_Twisted Thu Jun 02, 2022 9:45 am
@Aoktar
Is the Brigade kernel still planned for XB2 or RC1?
Tim_Twisted
Postby aoktar » Thu Jun 02, 2022 9:58 am
aoktar Thu Jun 02, 2022 9:58 am
Tim_Twisted wrote:@Aoktar
I think it's for next SDK but not sure.
Postby Tim_Twisted » Thu Jun 02, 2022 10:07 am
Tim_Twisted Thu Jun 02, 2022 10:07 am
aoktar wrote:I think it's for next SDK but not sure.
Thanks for the update. Really looking forward to it so hope it (or at least a beta) comes out rather soon.
Tim_Twisted
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 17 guests
Sat Apr 27, 2024 4:56 am [ UTC ]
