Version 4 - XB3-R1 (Experimental)
Forums: Version 4 - XB3-R1 (Experimental)
Moderator: aoktar
Re: Version 4 - XB3-R1 (Experimental)
Postby aoktar » Thu Aug 02, 2018 2:12 pm
aoktar Thu Aug 02, 2018 2:12 pm
VVG wrote:
aoktar wrote:
VVG wrote:Aoktar, give us information when?
1. soon (c) otoy :D
2. soon, soon
3. give me more time
I'm working on since new SDK out! It's a bit more work than I expected!
thaks for the info.
Every plugin is a different software which connects host and octane core. And any feature of CORE needs to be implemented well and integrated tightly. So it's not a matter of minutes as somebody thought. Sometimes it can be very complicated to inject or sometimes very quick!
Postby VVG » Thu Aug 02, 2018 4:25 pm
VVG Thu Aug 02, 2018 4:25 pm
aoktar wrote:Every plugin is a different software which connects host and octane core. And any feature of CORE needs to be implemented well and integrated tightly. So it's not a matter of minutes as somebody thought. Sometimes it can be very complicated to inject or sometimes very quick!
Soon you will have even more work with the output of R20, new API, new feature.
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
VVG
Postby aoktar » Thu Aug 02, 2018 5:31 pm
aoktar Thu Aug 02, 2018 5:31 pm
I'm worried about that! It may bring some big problems to us, we'll see after our stable releases.
Postby helloimneil » Fri Aug 17, 2018 10:57 pm
helloimneil Fri Aug 17, 2018 10:57 pm
Could someone ELI5 how to get rendered denoising frames from the picture viewer?
This is what I've done.
OCTANE RENDER SETTINGS:
*Unchecked save
*Inside Octane Renderer 'Render Passes' tab, I've clicked 'Enable', 'Show Passes', 'Show Beauty', 'Multilayer file'
*Under 'Denoiser Passes', I've selected 'Denoised Beauty' and 'Denoised Remainder'
DENOISER SETTINGS:
*Inside of the Octane camera tag under the 'Camera Imager' tab, I've clicked 'Enable' under the 'AI Denoiser' option
*Denoise on completion is checked on
*Min. denoiser samples are set to 100
When I render, the resulting image is black.
However, inside of the picture viewer I can see the render layers and when I click on 'Denoised Beauty', I am able to see the denoised image.
What am I doing wrong?
Could someone make an explainer video of what to do? I'd totally Venmo you some cash for your troubles.
Peace and harmony
helloimneil
Postby bepeg4d » Sat Aug 18, 2018 6:27 am
bepeg4d Sat Aug 18, 2018 6:27 am
Hi helloimneil,
if you are correctly seeing the denoised result in Picture Viewer, probably there is something wrong in the way you save that results.
Please, post a screenshot of the Camera Imager node, main tab, and a screenshot of the Render Settings/OctaneRender/Render Passes tab.
ciao Beppe
Postby helloimneil » Sat Aug 18, 2018 7:05 am
helloimneil Sat Aug 18, 2018 7:05 am
I was able to get the solution I needed via the Octane Facebook group.
It was in fact due to the way I had my saving options selected.
I'm absolutely thrilled with the denoising.
I know that the devs (aoktar) have said that it's not production ready, and I'm sure with more advanced projects it's not. However, for the project I'm working on currently, this has been an incredible boon.
One frame of my current project was taking around 12.5 minutes to render. My workstation has 2x 1080 TIs and 1x 1070. With denoising turned on the render times are around 1 min 5 seconds.
Seriously blown away by this new addition. Have rendered well over 100 frames with no issues whatsoever.
Way to go devs!
helloimneil
Postby bepeg4d » Sat Aug 18, 2018 7:12 am
bepeg4d Sat Aug 18, 2018 7:12 am
Hi helloimneil,
great to hear that the issue is solved, and you are enjoying v4 :)
Happy GPU Rendering,
ciao Beppe
Postby speedracerlo » Wed Oct 17, 2018 3:30 am
speedracerlo Wed Oct 17, 2018 3:30 am
my C4D experimental has stopped working. It said there is a new version and I need to update, but I don't see anything new here?
speedracerlo
Postby aoktar » Wed Oct 17, 2018 10:29 am
aoktar Wed Oct 17, 2018 10:29 am
speedracerlo wrote:my C4D experimental has stopped working. It said there is a new version and I need to update, but I don't see anything new here?
Latest V4 here
viewtopic.php?f=85&t=68928
Postby imago10 » Thu Oct 18, 2018 9:48 am
imago10 Thu Oct 18, 2018 9:48 am
Small question. When will be final Octane 4 TIER version available for C4D? Do you guys think in this year it's possible?
imago10
Previous
Return to Releases
Sat Jun 15, 2024 8:40 pm [ UTC ]
