Motion Blur stops rendering
Forums: Motion Blur stops rendering
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby coilbook » Sat Mar 18, 2017 7:01 pm
coilbook Sat Mar 18, 2017 7:01 pm
Hi if open this scene and make sure slider is where morph keys are and then open octane viewport renderer will get stuck at sample 1. If you go to octane options and uncheck motion blur it will work. It has something to do with moph modifier and poly edit above it. Especially if some vertices are selected in the edit poly mod above morphs
mb.zip
(1.88 MiB) Downloaded 147 times
coilbook
Re: Motion Blur stops rendering
Postby paride4331 » Mon Mar 20, 2017 10:04 am
paride4331 Mon Mar 20, 2017 10:04 am
Hi coilbook,
I have not found your issue, maybe I did not understand.
Could you make some screenshots or video?
paride4331
Postby coilbook » Tue Mar 21, 2017 2:06 am
coilbook Tue Mar 21, 2017 2:06 am
hi i attached the picture hopefully it helps.
if you select vertices and move slider and then open octane viewport rendering is stuck at sample 1. Please make sure Motion Blur is on
coilbook
Postby paride4331 » Tue Mar 21, 2017 12:42 pm
paride4331 Tue Mar 21, 2017 12:42 pm
Hi coilbook,
thank you
paride4331
Return to Bug Reports
Fri Apr 26, 2024 5:29 am [ UTC ]
