OctaneRender® for 3ds max® v2022.1.1 - 13.21
Forums: OctaneRender® for 3ds max® v2022.1.1 - 13.21
Re: OctaneRender® for 3ds max® v2022.1.1 - 13.21
Postby paride4331 » Mon Aug 28, 2023 10:57 am
paride4331 Mon Aug 28, 2023 10:57 am
coilbook wrote:1. Why does octane divide screen into 4 during rendering? And one quarter is always slow to render
2. Why does AI light work well with octane lights but not with VDB lights(fire) or mesh emitters?
Hi coilbook,
Uncheck "minimize traffic".
paride4331
Postby coilbook » Wed Aug 30, 2023 1:20 am
coilbook Wed Aug 30, 2023 1:20 am
Hi coilbook,
Hi Paride,
Were you able to find the problem about mb direction with phoenix liquids?
There is also another problem with vdb when it is attached to a moving object. It does the opposite motion blur. When vdv is attached to a moving car, for instance, and a camera is also linked to the car then flames should not have any mb but they do. The same problem was with itoo forest. Thanks
coilbook
Postby mbetke » Fri Sep 01, 2023 6:38 am
mbetke Fri Sep 01, 2023 6:38 am
Quick off-topic question: Why is it we don't get the Beta versions of new 2023 versions? New development strategy?
PURE3D Visualisierungen
Sys: Intel Core i9-12900K, 128GB RAM, 2x 4090 RTX, Windows 11 Pro x64, 3ds Max 2024.2
mbetke
Postby paride4331 » Fri Sep 01, 2023 10:44 am
paride4331 Fri Sep 01, 2023 10:44 am
Hi coilbook,
Temporary issue with the Phoenix license; nevertheless, I have forwarded your issue to the developers.
paride4331
Postby merid888 » Sat Sep 02, 2023 8:52 pm
merid888 Sat Sep 02, 2023 8:52 pm
coilbook wrote:
merid888 wrote:Does anyone have this problema with heightmap ?
Appear Image I/O error
Thank you if someone can help me
Try jpeg instead of tif
Hi coilbook I can't save the original map like jpg or png, Photoshop don't have this options in your format.
Add image like reference.
W11 x64 Bits Workstation, 32 Gb 3200 Mghz DDR4 Corsair, Asus X570 Plus Wifi, Ryzen 9 5950x 3.4 Ghz, M2 WD Black-SN850x 1 Tb, Corsair H100i RGB PLATINUM, 1 RTX A4000 16 GB, 1 Power Supply Corsair RM850x.
merid888
Postby coilbook » Tue Sep 05, 2023 5:16 pm
coilbook Tue Sep 05, 2023 5:16 pm
1. Sometimes during complex scenes octane crashes network adapter in the master. Not sure if they cannot handle too much of octane data transfer (net traffic is minimized). We tried 3 different adapters they crash during complex scenes.
2. Bug with itoo sometimes octane renders itoo as actual itoo proxies if points-cloud not used as a display mode. When using legacy mode for itoo sometimes it wont even render itoo unless you refresh. Direct mode is slow due to rebuilding and eval times every frame
3. When you have a moving car, for instance, that is linked to a moving non rendearable body and you select everything and uncheck Dirt Visibility strange things happen like some movable proxies don't get updated. etc
4. Direct mode doesn't work with itoo only legacy
5. When using HDR for sky rendering slows down a lot (Almost twice including slower eval) unlike when you use JPEG for sky. Even overall octane viewport is about 3-4 times slower when using HDR instead of jpeg
6. Rendering complex animation scenes clogs vram? and makes eval for the next scene too slow. Especially when using denoiser
coilbook
Postby coilbook » Tue Sep 05, 2023 11:30 pm
coilbook Tue Sep 05, 2023 11:30 pm
Maybe collapse the layers and try to save as jpeg or find tif to jpeg converter
coilbook
Postby neonZorglub » Tue Sep 12, 2023 5:22 am
neonZorglub Tue Sep 12, 2023 5:22 am
coilbook wrote:Hi Paride,
Phoenix liquid motion blur direction is still wrong. It has 45 degree direction
When can they fix it?
Hi coilbook,
The samples for liquid motion blur are still working :
viewtopic.php?f=27&t=81108
I know that there's not much information when some settings are incorrect; we'll try to add some diagnostic system..
-Make sure all the velocities are created by Phoenix.
-For the liquid mesh, check the Export as that should be 'mesh', and Velocity channel ID of the Phoenix object that should be 2..
Could you send a small sample if that doesn't work ?
neonZorglub
Previous
Return to Releases
Users browsing this forum: No registered users and 8 guests
Sat Apr 27, 2024 9:40 am [ UTC ]
