OctaneRender® for 3ds max® v2022.1 - 13.13
Forums: OctaneRender® for 3ds max® v2022.1 - 13.13
Re: OctaneRender® for 3ds max® v2022.1 - 13.13
Postby coilbook » Wed Jan 04, 2023 8:57 pm
coilbook Wed Jan 04, 2023 8:57 pm
HHbomb wrote:@coilbook
check if in Render setup > common > Assign renderer > Material editor : you have Octane render
Thank you!
coilbook
Postby coilbook » Sat Jan 07, 2023 5:02 am
coilbook Sat Jan 07, 2023 5:02 am
Where is old volume behavior checkbox? Smoke now looks too flat. Thanks
coilbook
Postby neonZorglub » Sun Jan 08, 2023 10:55 pm
neonZorglub Sun Jan 08, 2023 10:55 pm
coilbook wrote:Hi,
Hi coilbook,
This has been moved to the new 'Compatibility modes' system.
See the bottom of this post:
viewtopic.php?f=24&t=80814
For 'old volume behavior', set for example '2021.1 compatibility mode (with 4.0 volumes)' in Kernel / Direct light / Compatibility mode.
You can read details for each mode in the tooltip of this combo box.
Also, in Octane Preference, you can use the menu 'Info' to list all the modes available in all nodes.
neonZorglub
Postby coilbook » Tue Jan 17, 2023 1:08 pm
coilbook Tue Jan 17, 2023 1:08 pm
neonZorglub wrote:
coilbook wrote:Hi,
Hi coilbook,
Thanks. Why does smoke look worse with a new mode? It looks flat.
coilbook
Postby merid888 » Sun Jan 29, 2023 3:33 pm
merid888 Sun Jan 29, 2023 3:33 pm
Good morning, when I try to send the render, appear this message, I need restar my pc and run again open OctaneRender viewport and works fine, any bug of the version ?
I mean in the version 13.15 is whorse the error, many times is repetive this message even when I restar my pc and I finish doing a new scene and works fine
And this version 13.13 is less this message but is a problem I want to believe
Thank you you can help me OctaneRender team.
W11 x64 Bits Workstation, 32 Gb 3200 Mghz DDR4 Corsair, Asus X570 Plus Wifi, Ryzen 9 5950x 3.4 Ghz, M2 WD Black-SN850x 1 Tb, Corsair H100i RGB PLATINUM, 1 RTX A4000 16 GB, 1 Power Supply Corsair RM850x.
merid888
Previous
Return to Releases
Sat Apr 27, 2024 7:05 pm [ UTC ]
