2RTX GPUs with NV link and Carrara Octane
Forums: 2RTX GPUs with NV link and Carrara Octane
Carrara (Integrated Plugin developed by Sighman)
Postby protovu » Sat Mar 14, 2020 4:59 pm
protovu Sat Mar 14, 2020 4:59 pm
Hi Simon,
Is there a stable CarraraOtcane version that supports this?
If so, is the RTX enablement within Octane, or somewhere else?
Rick
Win10
Ryzen 3900x
64RAM
2-RTX2080s
protovu
Re: 2RTX GPUs with NV link and Carrara Octane
Postby Sighman » Sun Mar 15, 2020 11:14 pm
Sighman Sun Mar 15, 2020 11:14 pm
RTX with NVLink is available in 2020.1. 2020.1 is not officially released yet so you should not use it in a production environment.
The OctaneRender for Carrara plugin uses the same device settings as the stand-alone. So if you enable RTX in the stand alone you are also enabling it in the plugins. Having said that, with update 4 (RC2) of the plugin you can now enable RTX in the Device settings within Carrara. Open the render port, open Settings and then select the Devices tab. Click on the button to open the device settings. The device settings window is not a top most window so it can be hidden behind the render port or even behind Carrara itself. Use <Alt>-Tab to select it on Windows 10 or minimize the other windows.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Sighman
Postby protovu » Mon Mar 16, 2020 4:31 pm
protovu Mon Mar 16, 2020 4:31 pm
Thank you, Simon.
protovu
Return to Carrara
Users browsing this forum: No registered users and 18 guests
Sun Apr 28, 2024 12:36 am [ UTC ]
