Region Render bug
Forums: Region Render bug
Carrara (Integrated Plugin developed by Sighman)
Region Render bug
Postby tschwenke » Sat Oct 01, 2016 5:20 pm
tschwenke Sat Oct 01, 2016 5:20 pm
It seems that there is a bug in the region render in 3.03.03.20. If I want to region render an animation, it just does not go forward :(
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 18.5 || Win10 || i7 + 1 x RTX3080
tschwenke
Re: Region Render bug
Postby Sighman » Sat Oct 01, 2016 5:29 pm
Sighman Sat Oct 01, 2016 5:29 pm
Can you explain to me what you mean by region render? In the plugin, region render is used to calculate more samples in an area of an image to help remove noise in that area. There is no support for this in an animation.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Sighman
Postby tschwenke » Sat Oct 01, 2016 5:34 pm
tschwenke Sat Oct 01, 2016 5:34 pm
In former versions, I could use the region render to render only a region of the whole image. This worked also fine in animation mode. However, now, the region render seems to render only one image and there is no movement in the "Sample statistics" in the left bottom corner of the window either :(
Best wishes,
Thomas
tschwenke
Postby Sighman » Sat Oct 01, 2016 9:11 pm
Sighman Sat Oct 01, 2016 9:11 pm
Huh, I had no idea that you could get render region to work that way. The Octane team changed the way render region works and the samples are no longer added to the total. This is probably why it has stop working the way you are used to. I will see if there is a way to restore this hidden gem...
Sighman
Postby tschwenke » Sat Oct 01, 2016 9:31 pm
tschwenke Sat Oct 01, 2016 9:31 pm
Hi Sighman,
Thanks. I don't use it very often, so it would be cool as a special feature, but if it's a lot of work, then I can go without it :)
Best wishes,
Thomas
tschwenke
Postby EddyMI3D » Sun Oct 02, 2016 7:37 am
EddyMI3D Sun Oct 02, 2016 7:37 am
Hello Thomas!
Region Render?
Did not find this up to now.
I like to use this for optimizing textures or "repairing" some minor faults without rendering a complete scene.
Where can I find this? Or better: how do I activate this?
I used Render Frame, but it's no good when you work with DOF.
Eddy
My Rig:
PC with AMD FX 8350 @ 4,00 GHz
Win 7-64
Nvidia GTX 760
Nvidia GTX 970 (only for rendering)
About 6 TB of disk space (768 GB of SSD)
Octane/Octane for Carrara
EddyMI3D
Postby Sighman » Sun Oct 02, 2016 6:13 pm
Sighman Sun Oct 02, 2016 6:13 pm
Sighman
Postby EddyMI3D » Sun Oct 02, 2016 8:01 pm
EddyMI3D Sun Oct 02, 2016 8:01 pm
Thank you!
My Rig:
Win 7-64
Nvidia GTX 760
EddyMI3D
Return to Carrara
Users browsing this forum: No registered users and 16 guests
Fri Apr 26, 2024 1:21 pm [ UTC ]
