Particles and Scatter node
Forums: Particles and Scatter node
Carrara (Integrated Plugin developed by Sighman)
Re: Particles and Scatter node
Postby Sighman » Tue Dec 20, 2016 4:09 pm
Sighman Tue Dec 20, 2016 4:09 pm
I think I know what the problem is. The parser I am using for the float value is culture aware. So in Germany your decimal separator is a comma, not a period. Unfortunately, this knowledge won't help because I treat a comma or a space as a value separator. I will have to issue a new fix to use an invariant culture parser instead.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Sighman
Postby tschwenke » Tue Dec 20, 2016 4:33 pm
tschwenke Tue Dec 20, 2016 4:33 pm
Yes, this make sense :)
http://www.thomas-schwenke.me
Houdini 18.5 || Win10 || i7 + 1 x RTX3080
tschwenke
Postby tschwenke » Tue Dec 20, 2016 4:43 pm
tschwenke Tue Dec 20, 2016 4:43 pm
Changed the culture setting to "point" replacing "comma." Now it works as expected :)
tschwenke
Postby Sighman » Tue Dec 20, 2016 4:46 pm
Sighman Tue Dec 20, 2016 4:46 pm
Or you could try this:
viewtopic.php?f=79&t=56881
Sighman
Postby tschwenke » Tue Dec 20, 2016 5:34 pm
tschwenke Tue Dec 20, 2016 5:34 pm
Great, works like a charm now :)
Will test it thoroughly, but right now, it works great!!!
tschwenke
Postby tschwenke » Tue Dec 20, 2016 6:31 pm
tschwenke Tue Dec 20, 2016 6:31 pm
Ok, works great. Here are some errors I noticed.
- Animation: When rendering in Animation mode, the image index does not go up. It stays at the same index. So, creating an animation is not possible.
- Time slider: When selecting another object, the image index will not update (go up or down). Only if the particle sphere is selected, the image index will update.
- Shader: When creating a new shader for the particles, Carrara will crash if OR Viewer is open.
Apart from these errors, it works really good :)
Best wishes,
Thomas
tschwenke
Postby tschwenke » Tue Dec 20, 2016 8:46 pm
tschwenke Tue Dec 20, 2016 8:46 pm
Apart from the small problems above, works really great. Thanks Simon!
DAZ Dragon in Carrara
tschwenke
Postby Sighman » Tue Dec 20, 2016 11:55 pm
Sighman Tue Dec 20, 2016 11:55 pm
Nice! :D
Sighman
Postby tschwenke » Wed Dec 21, 2016 8:45 am
tschwenke Wed Dec 21, 2016 8:45 am
Thx :)
tschwenke
Postby Sighman » Wed Dec 21, 2016 11:42 pm
Sighman Wed Dec 21, 2016 11:42 pm
tschwenke wrote:Ok, works great. Here are some errors I noticed.
Best wishes,
Thomas
These issues should now be addressed: viewtopic.php?f=79&t=56881
Sighman
Previous
Return to Carrara
Who is online
Tue Jun 04, 2024 6:32 am [ UTC ]
