how to fix sharp edges?
Forums: how to fix sharp edges?
Area for student license holders to post questions and discuss octane.
Postby max1e » Thu Nov 03, 2016 9:21 am
max1e Thu Nov 03, 2016 9:21 am
hi, i have question about edges. maybe its AA?
in attach image 2 example:
upper: cinema4d + octane
lower: cinema4d + vray
by vray image much smooth on edges. how i can render image in octane with smooth edges? on second image my octane settings. thanks
p.s. subscribers cant post in other forum section? its little bit strange :?
max1e
Re: how to fix sharp edges?
Postby Terryvfx » Thu Nov 03, 2016 10:08 am
Terryvfx Thu Nov 03, 2016 10:08 am
I don't quite get what you are asking, if it's about the round shader feature you can check that up per material in the common tab, If it's about alpha you actually want your alpha to look like that in the render that's called "straight" then in the compositing stage when you pre-multiply it you get a correct image without halos.
Terryvfx
Return to General Discussion
Users browsing this forum: No registered users and 15 guests
Fri Apr 26, 2024 11:32 pm [ UTC ]
