texture options in material template library
Forums: texture options in material template library
Area for student license holders to post questions and discuss octane.
Postby Bubbsel » Wed Apr 22, 2015 9:55 pm
Bubbsel Wed Apr 22, 2015 9:55 pm
Hello Guys a new question,
I need to use the scale option for my textures. Is there a way to set the scale values already in the material template library. According to a Wikipedia article I have to set the line for scaling like "map_Kd -s 1 1 1 lenna.tga" where s stands for scale, but it doesn't work :/.
Is there another way to do it automatically?
David.
Bubbsel
Re: texture options in material template library
Postby abreukers » Thu Apr 23, 2015 6:11 am
abreukers Thu Apr 23, 2015 6:11 am
hi David, do you mean the textures in the liveDB? also, just want to make sure which version you're using, is that v1.20?
There is a scale value that can be adjusted as shown here:
the example above uses a texture by user Elvissuperstar, from the LiveDB.
abreukers
Postby Bubbsel » Thu Apr 23, 2015 11:21 pm
Bubbsel Thu Apr 23, 2015 11:21 pm
yes it is version 1.20.
I know this scale value in the options. But I use only scripted console commands to render my images.
So I don't want to use the this value. Therefore I'm looking for an alternative way without adjust the value manually.
Bubbsel
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 21 guests
Fri Apr 26, 2024 2:45 pm [ UTC ]
